Keep VAF
Going
w/a Donation
VAF on Twitter:
@VansAirForceNet
05-23-2023, 07:42 PM
Name this alternator
Hope some fellow aviators can tell me some info about my alternator. It’s working fine, but I want to find out if it has over voltage protection. I didn’t build my plane and I believe vans sold these back in the day.
Make?
OV protected?
Anybody had issues?
Reason I ask is Uavionix said my AV 30 failed from a voltage surge. Nothing else failed and my standard voltmeter stayed stable at 14.4v. Plus the AV 30 specs claim max input 60v. I’m pretty sure I’d seen smoke with that.
Hope you can help.
Thanks John
RV-4
N36WG
Take off is optional, landing is mandatory... Keep all your landings intentional...
Dues paid 2023
05-23-2023, 08:46 PM
An AV30 was gonna fail soon regardless Looks great, highly unreliable. Been thru 3, uAvionics always had an excuse to avoid any warranty consideration.
Seems you always get what you pay for. Sometimes Less!
George
05-23-2023, 08:51 PM
I'll name your alternator Bob.
Thanks for the heads up about Uavionix. Seems like they don't want to stand behind their product. A voltage surge wouldn't affect only one thing in your system.
05-23-2023, 09:20 PM
been here awhile
Looks like the 30a Nippon Denso that was sold by Vans and commonly used back in the day, I've flown them on my RV-6 since 1999. It is externally regulated and doesn't have OV protection built-in. I have an OV protection module that pops the alternator breaker but that is separate from the alternator.
Common number for the alternator is 14184, application is 1979 Honda Civic CVCC, no air conditioning.
Sam Buchanan
RV-6
05-23-2023, 09:44 PM
Ditto what Sam said. Same for my RV6.
05-23-2023, 09:57 PM
Thank you guys for the info!!
RV-4
N36WG
Dues paid 2023
05-23-2023, 10:01 PM
George
Had the same experience with them!! Probably gonna put my original VSI back in. This was my second AV30 since May 2020
RV-4
N36WG
Dues paid 2023
05-24-2023, 12:12 AM
Name this alternator.... let's call it sparky!
Los Angeles
RV-7 Builder
www.davidkarlsberg.com
05-24-2023, 04:20 PM
Hi Sam, does this zener diode location look correct??
Seems like it isn’t really doing much going from the 12v alternator post to ground. I think this was a failed attempt at over voltage protection. Seems like it’d just get hot as heck but not trip a fuse or breaker! Thought maybe you had an original set of instructions from vans that came with your alternator.
John
RV-4
N36WG
Dues paid 2023
05-24-2023, 04:49 PM
The Zener diode is not OV protection
John,
Here is a paragraph from the document which came with my alternator 26 years ago, it describes the purpose of the zener diode.
Here is the full alternator document in pdf format for your files.
Back then, the over voltage protection was usually based on an article in Bob Nuckolls Aeroelectric Connection book and described as crowbar over voltage protection. As Sam described, it was a separate circuit between the alternator and the main bus. You probably have it, but just haven't found it yet. At least that's my guess.
Thread Tools |
Search this Thread |
Display Modes |
Linear Mode
