How is everyone draining the coolant lines without making a mess with the Dexcool when you change the rubber hoses? Also a thank you to Seagull for your list of supplier and parts.
A bucket under the radiator. Disconnect the lower hose first. Also put towels under each connection point as you pull off hoses. You will get a little each time
Just did this yesterday
