Old 06-09-2022, 12:49 PM
Piper J3's Avatar
Piper J3 Piper J3 is offline
Default How to Re-calibrate Autopilot Servo with Dynon HDX?
Iím helping a RV-12 friend that has dual Dynon HDX with Autopilot. He replaced the sheer screw in the roll servo and now needs to re-calibrate the servo. We canít find exact instructions for doing this with HDX. We found Dynon SkyView instructions, but they donít correlate to the HDX. We have a call into Dynon. Any help appreciated...
Jim Stricker - EAA #499867
PPL/ASEL 1970 - Sport Pilot since 2007
80 hrs Flying Aeronca Chief 11AC N86203
1130 hrs Flying 46 Piper J-3 Cub N6841H
Bought Flying RV-12 #120058 Oct 2015 with 48TT - Hobbs now 815
LSRM-A Certificate 2016 for RV-12 N633CM
Special Thanks... EJ Trucks - USN Crew Chief A-4 Skyhawk
MJ Stricker (Father - CFI) - USAAF 1st Lt. Captain B-17H
Old 06-09-2022, 12:57 PM
pazmanyflyer's Avatar
pazmanyflyer pazmanyflyer is offline
Originally Posted by Piper J3 View Post
I’m helping a RV-12 friend that has dual Dynon HDX with Autopilot. He replaced the sheer screw in the roll servo and now needs to re-calibrate the servo. We can’t find exact instructions for doing this with HDX. We found Dynon SkyView instructions, but they don’t correlate to the HDX. We have a call into Dynon. Any help appreciated...
Procedure should be the same for the HDX.
https://www.google.com/search?client...gkPIPj-Ww2AM32
Also see Section 6.3 Servo Calibration Procedure in the manual.
https://www.google.com/url?sa=t&rct=...2DpASQwvanVqwT
Van's also provided this PRE-SET READ ME document to RV12ers. Maybe this will help too?
https://www.google.com/url?sa=t&rct=...FXfW8Igxgv-IL2
Carlos in Arizona
EAA Chapter 538 www.chapters.eaa.org/eaa538
Wittman Tailwind W8 N53CH (built & sold)
Pazmany PL-1 N2029 (bought & sold)
RV7 - N537TC (reserved & building)
Emp, Wings & Fuse done - working on FWF
"The air is an extremely dangerous, jealous and exacting mistress. Once under the spell most lovers are faithful to the end, which is not always old age." - Winston Churchill
Old 06-09-2022, 01:00 PM
jcarne's Avatar
jcarne jcarne is offline
Edit: sorry misread your post, my explanation below is for tuning not calibrating.
Long story short Dynon hasn't released an updated version in quite awhile. The "current" tuning guide does not have any guidance on many of the setting that were added in 16.0 updates. So, still go through the same tuning guide. If you mess with settings not in the tuning guide you are on your own to some degree.
Many of us have been asking for an updated tuning guide for awhile now. Post number 4 here is the best we have at this point on many of the settings.
Jereme Carne
PPL
RV-7A Flying as of 03/2021
Old 06-09-2022, 02:45 PM
StephenC's Avatar
StephenC StephenC is offline
Try
SETUP MENU > HARDWARE CALIBRATION > AP SERVO CALIBRATION > TEST
Old 06-09-2022, 04:59 PM
Piper J3's Avatar
Thank you for steering us in right direction.... literally....
