Old 01-24-2022, 10:16 AM
Ironflight's Avatar
VAF Moderator / Line Boy
Default For the Skiers……
Just saying….you don’t need a ski tube in an RV-6 to carry a pair of 174’s….
Caveats:
1) Yes, this makes it a one-person transport … but then again, you don’t have the payload for two people (in ski gear), boots, helmets, poles, etc. anyway if you want to stay below gross.
2) You need to remove the passenger stick!
3) CAREFULLY secure the tails of the skis so as not to interfere with the rudder pedals - in this case, we have the old style pedals, with a tube running across the floor, and the tails notch in between the floor and the tube, allowing rudder tube rotation without interference.
4) Removing the seat back makes it all even better - the skis rest on the cross-bar structure, can be secured to the structure with a strap, and you could probably get 200’s in there. The limitation is actually what will fit through the opening provided by the tip-up.
Not going to do this on a regular basis, but as a once-in-awhile thing, it works! And a lot easier than engineering a ski tube…..
Click image for larger version
Paul F. Dye
RV-8 - N188PD - "Valkyrie"
RV-3B - N13PL - "Tsamsiyu"
Dayton Valley Airpark (A34)
http://Ironflight.com
Old 01-24-2022, 10:18 AM
Bavafa Bavafa is offline
There is only one problem I can see here, where can one find snow to ski on?
Mehrdad
N825SM RV7A - IO360M1B - SOLD
N825MS RV14A - IO390 - SOLD
N258SM RV14A - IO390EXP119 - Out of Paint shop & flying
Dues paid
Old 01-24-2022, 10:32 AM
jneves's Avatar
jneves jneves is offline
Caveats:
Attachment 21391
Good to know, I was just thinking about taking a flight up to South Tahoe tog et some skiing in for the day and the first step was trying out the equipment for fit in the 6.
Thanks for sharing
Johnny
N455DM - RV-6A - Bought Flying - 2021
Tip Up Canopy
IO-360-A2B
FP 66" Catta 3 blade Carbon
IFR - 2 Garmin G5s - 430W - GFC500
JPI EMS-350 to monitor the temps
N89WD - Flight Design CTSW - Sold 2021
Donation Happily Made!
Old 01-24-2022, 01:26 PM
Ironflight's Avatar
Mammoth, June, and all of the Tahoe resorts got buried during the holidays, and are still doing fairly well!
Paul F. Dye
