Old 11-23-2021, 08:08 AM
HFS HFS is offline
Default 1/4" Diameter Flat Sets for Squeezers
Once in a while the smallest diameter squeezer sets - 3/8" is still too large for the job. I took a set of the 3/8 and turned them down to 1/4" diameter, then polished them. You hardly ever need them, but when you do ...
3/8" on the bottom, 1/4" on the top
HFS
Click image for larger version
Name:	1:4%22 Dia. Flat Sets.jpg
Old 11-23-2021, 09:26 AM
John Tierney John Tierney is offline
The narrower sets are handy in tight spots. I use one similar to the link below from ATS as a poor man's longeron yoke set.
https://aircraft-tool.com/shop/detail.aspx?id=AE1727
John Tierney
Vonore, TN
RV-7A - N777JT Flying
Old 11-23-2021, 09:34 AM
fl-mike's Avatar
fl-mike fl-mike is offline
Use them all the time for platenuts. I mostly use the one that came with the brake rivet set kit from Avery, but also have a couple others including a longer one I made. The old Southbend gets used more than I would have thought.
Mike W
Venice, FL
N164WM
N184P reserved (RV-8QB)
Old 11-23-2021, 12:14 PM
9GT's Avatar
9GT 9GT is offline
I have modified a couple AN-3 bolts to make custom sets for my squeezer.
David C.
Howell, MI
"Donor Exempt" but donated through Dec. 2021
Old 11-23-2021, 01:09 PM
jacoby jacoby is offline
Anyone know what the little retaining rings are called? I've made a couple of sets but without the retaining ring they like to fall out of the squeezer.
Old 11-23-2021, 02:54 PM
GeoffP's Avatar
GeoffP GeoffP is offline
Not sure of the name for the rings, but you could use a tiny O-ring in the groove, or just a bit of gorilla tape on the side to hold it in place.
RV-9, Empennage and Wings about done, Fuselage taking shape.
