Old 10-12-2021, 09:10 PM
WingnutWick's Avatar
WingnutWick WingnutWick is offline
Default "T" off MAP from NPT bulkhead fitting suggestions?
Installing the new P-Mags onto the IO-540 and I need to pipe them both to MAP. My current MAP setup has a 1/4 bulkhead fitting that I am wondering if anyone knows of an adaptor that would work between this to plumb off a MAP hose. It eventually needs to go to a 1/8 hose. Been looking at options and just curious if anyone has any simple solutions out there. Closest thing I have found is this banjo fitting but I'm not entirely sure it would work.
Thanks all!
https://www.aircraftspruce.com/catal...ickkey=3008137
Click image for larger version
ID:	17033  Click image for larger version
-Wingnut
F-18E/F, Mk.58, CF-5
RV-8 O-360
Old 10-12-2021, 09:29 PM
Richard Connell Richard Connell is offline
Default How I did it.
I split that aeroquip hose and put a tee and a nylon barb. I’m sure there’s plenty of ways to skin that cat.
Sorry for the rotates photo
Richard
RV7 VH-XRC Sold :-(
RV10 in progress.
Sydney, AUS
Old 10-12-2021, 09:41 PM
gmkonrad's Avatar
gmkonrad gmkonrad is offline
Would one of these work?
https://www.adlerspeed.com/products/...e-port-adapter
Gary
Gary
RV-7 FLYING
N319GK
Old 10-13-2021, 06:07 AM
MikeyDale's Avatar
I just finished installing duel P-Mags. This is what I used. Bought it off of EBay.
https://www.ebay.com/itm/25406303619...53.m2749.l2649
Mike Hillger
RV 7 FLYING SINCE 4/2015!
Garden City, Texas
Dues Paid
Old 10-13-2021, 06:37 AM
sailvi767 sailvi767 is online now
You can also just put a fitting into a primer port and run a dedicated line. Takes about 5 minutes.
RV-6 sold
F-1 Rocket
Old 10-13-2021, 07:31 AM
rmarshall234 rmarshall234 is offline
That's what I would do. You've got 5 more bites at the apple.
Old 10-13-2021, 07:58 AM
Default Perfect!
Perfect! Going to go with the -4 fitting with 1/8th female port....exactly what I was looking for. I think this is the path of least resistance.
Thanks all!
-Wingnut
RV-8 O-360
Old 10-13-2021, 10:45 AM
Charles---get a AN826-3D branch tee to screw into the swivel adapter. Then you can use some -3 hose end stems to connect the 1/8 PMag hose.
Many ways to do this.
Tom
Name:	AN826-3D with -3 hose ends.jpg
RV7A Tail Kit Completed, Fuse started-Pay as I go Plan, on hold while we develop new products for RV builders
Ridgeland, SC
Old 10-13-2021, 03:09 PM
Scott Hersha Scott Hersha is offline
I used a bulkhead “T” on mine, which would install right where your current bulkhead fitting is…
Zoom in to the lower right corner (if the picture shows upright). It’s the blue T. Hard line up to the engine mount tube, transitions to the silicone hose going the the mag. Install a barbed T in that line if you have 2 EI mags.
OK……. zoom in to the upper left for the blue T fitting…..
SH
RV6/2001 built/sold 2005
RV8 Fastback/2008 built/sold 2015
RV4/bought 2016/sold/2017
RV8/2018 built/Sold(sadly)
RV4/bought 2019 Flying
RV6/Used kit purchased 2021 building
Cincinnati, OH/KHAO
JAN2021
Old 10-14-2021, 07:05 AM
Tankerpilot75's Avatar
Tankerpilot75 Tankerpilot75 is offline
Tom
Or have TS Flightlines just make you a new hose with the proper fittings.
Jim Harris, ATP, T38, EC/KC-135A/E/R, 2008 RV7A, 2nd owner, N523RM (2015)
Superior XPIO-360, Hartzel CS prop, Dual GRT Horizon EX with ARINC, EIS, Garmin 340, 335 w/WAAS gps, Dual 430s (non-WAAS), TruTrak 385 A/P with auto-level & auto-trim, Tosten 6 button Military Grips, FlightBox wired to EX, Dynon D10A w/battery backup, 406 MHz ELT. Custom Interior, New TS Flightline hoses, Great POH!
Retired - Living the dream - going broke!
