w/a Donation
VAF on Twitter:
@VansAirForceNet
Old 08-29-2021, 09:13 PM
tommyroland tommyroland is offline
Default The Best Multitools for EDC to Buy: Buyer’s Guide and Reviews
Regardless of who you are and what you do, a good multi tool can make your life significantly easier. Most people have this idea that multi tools are made only for professional users like electricians, engineers, soldiers, and police officers.
That cannot be further from the truth.
Yes, the best multi tools can give much-needed aid to people in these professions. However, the average person (office workers, students, etc.) can benefit from top rated multi tools, as well. You’ll find out exactly why in this buyer’s guide of the best Everyday Carry (EDC) multi tools.
What is Everyday Carry (EDC)?
Everyday Carry (EDC) is more than just a bunch of rarely-needed gears. It’s a principle that revolves around preparedness and utility. Having an EDC kit means being prepared for whatever situation that may happen while you’re out and about.
It’s not necessarily life-and-death situations like most advertisements on the TV often tell you. Instead, it’s common, everyday scenarios like needing a knife blade to open up a box or an envelope. You don’t have to run around the office or the class to find a pair of scissors. Just reach into your pocket and flip out a blade from your most useful multi tool.
Many models also come with literally everyday tools like nail clippers, filers, and hair comb.
As you can see, your life can become much more convenient with a good EDC multi tool in hand.
What’s in a Best Rated EDC Multi Tool?
Our team looks for top rated multi tools with a set of criterias.
Design
Design is arguably the most important part of a multi tool design, especially one for EDC. A good EDC multi tool must be small, compact, and lightweight. It must be able to do a good enough job at these three things, you could forget that it’s even there in your pocket until you need it.
On the flip side, the lightest and most compact multi tools have a tendency to be structurally weak. Big, bulky multi tools like the Leatherman Wave Plus have a reinforced design and thus can handle very intense jobs like wood carving. Smaller multi tools don’t have that sort of benefit. They’re more fit for low-intensity jobs like box-cutting or electric wire-snipping (in some models with wire snipper.)
Tool Selection
Best multi tools must have a good tool selection.
That’s not everything we’re looking for, though.
The majority of the tool selections of a good EDC multi tool must also be useful to the user. You don’t want to pay north of $50 for a quality multi tool to end up only using 1 or 2 tools.
Multi tools either have pliers or a pair of scissors on its head. Depending on what you do and what you need, take your pick accordingly. Nonetheless, most people wouldn’t need a pair of pliers in their daily life. Scissors are going to be much more useful for cutting boxes, letters, plastic sheets etc.
Price
The price is also an important factor. You can find multi tools between $20 up to $200. The amount of money you’ll be spending depends on the brand and the model you choose from as well as the job you need a multi tool for.
EDC multi tools tend to be quite cheap. You can find a good pair between $50 and $100 without much of an issue.
The Best Multitool Reviews for EDC
With all that said, here are our picks for the best EDC multitools.
Gerber Dime
The Gerber Dime is small, compact, and affordable. It’s currently one of the best choices out there on the market if you’re seeking something that fits right into your pocket. According to our measurements, the Gerber Dime weighs only 2.2 ounces. It’s totally possible to forget all about it once you put it into your pocket.
It’s constructed from high-quality 3Cr13 stainless steel, thus, it’s quite durable and can withstand a lot of abuse.
The Gerber Dime comes with 12 different functions. First, you have spring-loaded, needle-nose pliers, standard pliers, then a wire cutter. You will get a small, fine-edge blade for cutting.
As for screwdriver, this multi tool comes with a medium flat head driver and a cross driver. Miscellaneous tools like tweezers, a bottle opener, package opener, coarse & fine file, lanyard ring, and scissors are included.
The Gerber Dime comes with a lifetime warranty.
Check This Out: Looking For The Best Multitool? Find Your One-In-A-Thousand
Leatherman Style PS
When asked the question: “Who makes the best multi tool?”, the most common reply you’re going to get is Leatherman.
The company is almost synonymous to multi tools at this point after releasing so many popular multi tool models. However, the company’s bult for itself a reputation for exclusively making bulky, elaborately-designed multi tools for professionals.
With the Style PS, Leatherman has proven that it can also make a multi tool that’s stylish, compact, and functional all at the same time.
The Leatherman Style PS weighs 1.56 ounce. The company achieved this in 2 ways: lighter materials and fewer tools. Rather than having a full stainless steel construction, the Style PS is made from a mixture between stainless steel and glass-filled nylon. Additionally, this best rated multi tool only carries 8 tools.
You have a spring-action needlenose, regular pliers, as well as spring-loaded wire cutters and scissors. The kit also contains a Phillips screwdriver alongside a flat driver. Extra tools include tweezers, nail file, carabiner, and bottle opener.
The best thing about the Style PS is that it is TSA-compliant. It doesn’t come with a knife blade, so it can go through airport security just fine. Just make sure that you deploy all of the tools and tell the security officer that you’re bringing with you a multi tool before you pass the checkpoint.
Victorinox SwissCard Lite
Victorinox is one of the best multi tool brands on the market. Considering the fact that the modern-day multi tools took much inspiration from the Swiss Army knives, certainly Victorinox— a Swiss brand— would know a thing or two about making good multi tools.
They did that with the SwissCard Lite.
It doesn’t have the traditional pliers-like design of multi tools. The SwissCard Lite is designed in a rectangular package that looks similar to a credit card. It also feels like a credit card when you pick it up. After all, the whole thing barely weighs an ounce and is made from ABS plastic and Cellidor (an organic, tough compound.)
The size of the SwissCard Lite is small enough that you can fit it into the ID compartment of your wallet without issues.
But despite the small, innocent, and lightweight design, the SwissCard Lite is a truly capable multi-purpose toolbox. Inside of the card are 13 different tools. This includes a letter opener (or “emergency blade”), a pair of scissors, magnifying glass, 3mm and 5mm screwdrivers, Phillips 00/0 and ½ screwdrivers, tweezers, a ballpoint pen, and an LED flashlight.
You’ll also find measurement units (in centimeters and inches) on the card and can use it as a ruler when needed.
All of the tools are constructed from stainless steel, so don’t worry about durability.
Read The Article: https://thekinglive.com/leatherman-skeletool-cx-multitool-review.html
Conclusion
We hope you have enjoyed these best multi tools reviews and have found for yourself a fitting EDC multi tool!
But just in case you haven’t found what you’re looking for, we got a few more selections in other articles waiting for you. In the meantime, happy shopping!
Old 08-30-2021, 01:58 PM
n82rb's Avatar
n82rb n82rb is offline
flyleds
bob burns
RV-4 N82RB
Old 08-30-2021, 03:28 PM
nzrv8's Avatar
nzrv8 nzrv8 is offline
+1 for FlyLeds. Cost effective, and super bright.
Paid up - Sep 2022
