Old 05-10-2021, 02:06 PM
8s_Great 8s_Great is offline
Default Wide Foot / Feet Getting stuck on Rudder Pedals
Hello All
Couldn't find anything with the search function. When it comes time to steer or use the pedals at all, my feet are so wide that they get caught inside the pedals and when I try to pick my feet off the pedals or move them up and down, the pedals come with my feet or won't let me slide up or down. Any thoughts? Narrow shoes hurt my feet.
Old 05-10-2021, 02:10 PM
riseric's Avatar
riseric riseric is offline
Default Racing shoes/boots
Did you try racing shoes or boots??
They can be really thin and supple.
And their rounded heel makes it confortable to move the feet on the floor.
Eric,
2021 dues happily donated
RV-8 slow built #83274
Grove Airfoiled Gear, Wheels & Brakes
VPX-Pro, EFII System 32, EarthX batteries
Aerosport IO-375, MTV-9-B/183
Skyview HDX
C-GEMQ
Final inspection done!! Waiting for CofA
C-72R Cutlass, flying
Old 05-10-2021, 02:23 PM
I haven't tried race shoes. I will give that a shot. Somehow I feel like they will be narrow and painful as well. But I'll keep an open mind.
Old 05-10-2021, 02:26 PM
bill.hutchison bill.hutchison is offline
I have a friend with a similar issue - he started wearing wrestling shoes and his problem went away. Bonus, they're super comfy.
I wear Saucony Bullets (nice, unobtrusive sneakers - look em' up) every day and fly in them all the time. They're the most comfortable thing I've ever owned. I got the tip from a Citabria guy who was teaching me some tailwheel/aerobatics a while back. They're almost like socks.
Old 05-10-2021, 03:14 PM
Daveflier Daveflier is online now
Default This might work
Take an old pair of running shoes and use your Dremel to trim off the built up heel portion. Then sand or smooth down the area. It makes a world of difference moving your feet fore and aft on the pedals.
I mainly fly aerobatics in my -8 and always change footwear prior to flight.
Old 05-10-2021, 03:55 PM
swjohnsey swjohnsey is offline
Converse Allstars also work well.
Old 05-10-2021, 05:56 PM
Ron B. Ron B. is offline
Try smaller feet.
Thanks Ron
RV-10 SOLD
RV-14 Flying
AirCam flying
Old 05-10-2021, 07:26 PM
Robert Sailor Robert Sailor is offline
I’ve got very wide feet as well and I found some Puma running type shoes...although they are not typical runners that are wide enough for my feet but the overall width is way narrower than typical runners. The soles are thin and I can feel everything through them...had a little aerobatic biplane I originally bought them for but they are perfect for the RV.
Old 05-10-2021, 08:08 PM
jklusman jklusman is offline
I had the same problem in my RV-8. Solved it immediately by purchasing boat shoes, which turned out to be the most comfortable shoes I own. Mine are Dockers.
Old 05-10-2021, 08:13 PM
Scott Hersha Scott Hersha is offline
I understand your problem. However, my RV4 seems to have a little more room between the rudder pedal flanges than the newer RV models, and most “normal shoes” are working out OK. A few years ago I bought a pair of ‘Piloti’ driving shoes when I had my RV8, and they worked OK as far as rudder pedal controllability is concerned. It was narrow in the fore foot area where it didn’t get hung up between the rudder pedal flanges, and it has a rolled heel, which works well with rudder pedal manipulation without brake application in a tail dragger. However, it has virtually no other redeeming qualities. It offers zero heel support or cushioning and no foot support of any kind. In three years, I’ve used mine three times. They are probably the worst pair of shoes I’ve ever waisted too much money on (they are not cheap). You can modify a pair of athletic shoes that you’ve purchased at DSW, or any place, with your dremel (as others have stated), and you’ll have your solution with a shoe you can wear outside the cockpit.
SH
RV6/2001 built/sold 2005
RV8 Fastback/2008 built/sold 2015
RV4/bought 2016/sold/2017
RV8/2018 built/Sold(sadly)
RV4/bought 2019 Flying
RV6/Used kit purchased 2021 building
Cincinnati, OH/KHAO
JAN2021
