Old 05-03-2021, 05:24 PM
s24789 s24789 is offline
Default Lost right brake
We lost our right brake while turning on to the runway for takeoff. Spun around a couple of times and got it stopped. Saw fluid leaking out of failed brake. After the 1/2 mile walk/pull back to the apron we pulled the fairing and saw the puck fully extended. Got a ride back to home base from a friend and packed the car to fix the problem. Pads were extremely thin and I believe that coupled with the original brake rotors allowed the puck to extend past the seal.
Thinking we need to replace out brake rotors as well and am looking for suggestions of Rapco vs Cleveland. Price for the Cleveland is X2.
Thoughts ?
Kevin Phelps
Paid thru Dec 2021
RV-7A flying N782WP
Stuart, Fl
Old 05-03-2021, 05:40 PM
Ed_Wischmeyer's Avatar
Ed_Wischmeyer Ed_Wischmeyer is offline
Rapco, near as I can tell.
RV-9A at KSAV (Savannah, GA; dual G3X Touch with autopilot, GTN650, GTX330ES, GDL52 ADSB-In)
Previously RV-4, RV-8, RV-8A, AirCam, Cessna 175
ATP CFII PhD, so I have no excuses when I screw up
Too many safety posts purged without notice...
Old 05-03-2021, 06:07 PM
Plummit's Avatar
Plummit Plummit is offline
Rapco is fine, you might also look into APS Black Steel, but I don't know the price point.
-Marc
RV-10
N814RV
2021 Donation Made
Old 05-03-2021, 06:28 PM
RVbySDI's Avatar
RVbySDI RVbySDI is offline
+1 Rapco. Of course I am just giving blind advice via the internet so take it for what you paid for it but unless there was a lot of metal scraping it is hard to imagine there was enough damage to need to replace the rotors.
RVBYSDI
Steve
RV9A
https://rvwings.com
Live Long And Prosper! 🖖🏻
Old 05-03-2021, 06:37 PM
Gisnar Gisnar is offline
Kevin,
Very, very glad you did not get airborne!
Recently lost a tire on landing and with full brake on the opposite side plus some crosswind help was able to keep it on the runway. Had to be towed back to hangar.
Suspect with one brake you would have had an interesting time on landing.
Old 05-03-2021, 06:51 PM
pilotkms's Avatar
pilotkms pilotkms is offline
I change my pads at every CI. I fly almost 200 hours a year. Rarely have I used 1/2 the pads. I use the Matco reline service. $35. Cheap insurance. No desire to get stuck in the far off places I fly.
Keith
RV 7A RV #9700 May 2017
N325KS the Flying K
Built in SoCal KCCB, now in GA @ KPXE
600+ Hours & 7X cross the USA
OSH flyin 2018 & 2019 & Petit Jean 2019
Old 05-03-2021, 07:19 PM
molson309 molson309 is offline
I had this happen on the RV7A when the pads got thin, and this was on relatively new rotors. It pays to replace the linings before they wear down that far. In my case I lost the left brake when pulling away from the gas pump and I thought I needed to use that brake to avoid hitting the pump. Fortunately I shut down fast enough that I avoided the collision but it was a very tense moment.
Mark Olson
RV-7A First flight 2005 Sold 2019
F1-EVO Rocket First flight 2010
Old 05-03-2021, 07:25 PM
BobTurner BobTurner is online now
I have read reports here on VAF of brake pistons that were installed backwards, e.g., their O rings became exposed with only a relatively small extension. You might check yours.
Old 05-03-2021, 07:33 PM
Finley Atherton Finley Atherton is offline
I replaced worn Cleveland rotors with thicker Rapco rotors (RA164-09900). Better braking and less fade. Requires longer calliper bolts and a 1/8” shim for each calliper.
Fin A
Old 05-03-2021, 08:23 PM
bhester's Avatar
bhester bhester is offline
Default Rapco
I used Rapco works good last long time.
When reinstalling the brake pucks be sure they go back in like this. O-ring side goes in first.
Bobby Hester - Builder/Pilot/A&P
Surfing the web from Hopkinsville, KY
N857BH RV7A XP-O360 - Garmin G3X ADS-B IN/OUT 2020 Compliant
Web site: http://www.newtech.com/bobbyhester/RVSite.htm
Dec. 2020 VAF donator - alot better than any magazine subscription
