Old 01-24-2021, 11:08 AM
Wasp26 Wasp26 is offline
Default GPS175 in new installation...
hello to all,
Following the failure of my NSD360 and my KLN90, I plan to make modifications on my RV8.
I have already installed a G5 and a GDU375, but without any link with the KI208 and the PA VIZION385.
I'm thinking of adding a GPS175 and linking it with all the other instruments, including the A/P.
Can you tell me if this installation is feasible?
Will it be possible to control the A/P via GPS or the HDG and ALT bug of the G5/GDU375?
On the other hand, I can't find the GPS175 installation manual to make the schematics. I use the CNG355 one which seems to be close...
Thanks if you can help me...
Click image for larger version
Name:	Architecture avionics RV8.jpg
__________
RV8 F-PJFC
Old 02-12-2021, 07:45 AM
pilotmansam pilotmansam is offline
I have purchased a GNC355 and trying to do the homework to interface to my other avionics. I have not done this before and need to do a lot of homework. Your situation looks easier than mine since you are mostly Garmin already. Perhaps we can help each other.
Sam Hart
Newberry, SC
RV-6A N7228Z
Old 02-12-2021, 08:16 AM
Raymo's Avatar
Raymo Raymo is offline
You'll also need the Garmin ARINC 429 box for communication between the 175/355/375 and other components. Not sure of AP compatibility but it should also work. When you purchase the 175, it will come with a black envelope containing information on registering the device, which will give you access to associated documents for 2 weeks.
Ray
RV-7A - Slider - N495KL - First flt 27 Jan 17
O-360-A4M w/ AFP FM-150 FI, Dual PMags, Vetterman Trombone Exh, SkyTech starter, BandC Alt (PP failed after 226 hrs)
Catto 3 blade NLE, FlightLines Interior, James cowl, plenum & intake, Anti-Splat -14 seat mod and nose gear support
All lines by TSFlightLines (aka Hoser)
Old 02-12-2021, 12:25 PM
Originally Posted by Wasp26 View Post
hello to all,
Many installers route the autopilot arinc lines thru a double pole double throw switch, selecting sending the arinc lines to either the efis or the gps. If gps is selected, you control the autopilot with its own controls; it functions even if the efis fails. If efis is selected, you control the autopilot with the efis controls. Most seem to prefer this.
BTW, you show the gps optionally driving the King indicator. Not sure if this will work. My guess is you can drive the needles but not use the OBS. Find the manual to verify. But, why bother? This is one more switch that can fail or be mis-set (and its a multipole switch - a lot of wires.) Id suggest you just hardwire it to the King Nav, and use the efis displays for the gps.
Old 02-12-2021, 01:44 PM
Avanza Avanza is offline
Smile ARINC 429 and RS 232
I believe that ARINC 429 contains vertical navigation and RS 232 the lateral
information. So RS 232 has to be connected to the autopilot.
Old 03-28-2021, 12:00 PM
Hello
Thank you very much for your answers.
I will continue on this way, but maybe without the GPS - KX165 switch.
@pilotmansam: it would be great if we could exchange information to advance our respective projects..... Do not hesitate to contact me....
Sincerely
__________
RV8 F-PJFC
Old 03-28-2021, 12:42 PM
Jpm757's Avatar
Jpm757 Jpm757 is offline
Installation manuals can be requested through Garmin support.
Jake
RV6 #20477 completed 1991 sold.
RV7 #72018 N767T first flight 11/21/2017
(KOXC)Oxford, CT, (0NY0)North Creek, NY.
1941 J3 Cub skis, floats.
Building Javron Super Cub.
2020 dues gladly paid.
Old 03-28-2021, 01:18 PM
uk_figs's Avatar
uk_figs uk_figs is offline
As I am considering upgrading to a 175/375 this is news to me, according to the gemini A/P manual if both 429 and 232 are connected the A/P defaults to the 429 input and rolls back to the 232 if no 429 signal is detected. It also states that you have to have 429 for coupled (3 dimensional) approaches i.e vertical guidance. I currently use the Aera 796 to drive the Gemini via 232 and was planning to couple the 175/375 via 429 and if for some reason it quits I can roll back to the 796 for GPS guidance (just not vertical).
I was also planning to connect the 2nd 429 channel from the 175/375 to the D100 to drive the CDI via the HS34 so that I could cycle through the SL30 VOR/ILS, 175/375, and Aera 796 navigation inputs.
I am no expert and currently studying for the instrument rating but would like to understand the interconnectivity as I plan my upgrade.
Figs
Dave (Figs) (RV-7 N256F, Flying)
Dave's RV-7 Blog
Email me
