Old 01-11-2021, 09:41 AM
rockitdoc's Avatar
rockitdoc rockitdoc is offline
Default Which FI?
Lycoming requires picking between Avstar and Airflow Performance. Both look like great choices, but which one?
Any opinions?
14A
Begun 07-23-20
Emp Completed 11-12-20
Slo Fuse Completed 3-2-21
Wiring and Avionics Begun 3-3-21
QB Wings delayed until ?
Finish Kit expected 7-21
Thunderbolt EXP119 expected 7-21
2021 Dues Paid
Reserved: N52XL
Old 01-11-2021, 09:48 AM
BoydBirchler BoydBirchler is offline
They are both nearly the same design. AFP has a few minor differences that may make it slightly better. So in my mind if cost is similar, I would go with AFP.
If there is a large additional cost, then I would go with the lower price.
Old 01-11-2021, 10:53 AM
DanH's Avatar
DanH DanH is offline
Definitely not the same design, just similar operating principle.
Right now you can't even get a service manual for an avestar. Airflow comes with a thick book and very good telephone service.
Dan Horton
RV-8 SS
Barrett IO-390
Old 01-11-2021, 10:59 AM
Nova RV Nova RV is offline
The AFP will require an adapter plate kit (available from AFP) to buy for control cable installation vs. kit and the intake snorkel requires a minor modification that takes a couple hours of time. That said, with AFP as Dan noted, the fact that you get an actual manual and also if you call them, you can talk to the owner of the company for support.
Chris Moon
Leesburg, VA
CFI-I ASMEL, ATP
RV-14A kit # 140243 (flying as of 11/18)
www.mykitlog.com/chrismoon/
Old 01-11-2021, 01:24 PM
rzbill's Avatar
rzbill rzbill is offline
I'm curious.
My YIO-360-M1B came with a Precision Airmotive RSA-5 clone.
Are they really not available through Lycoming any more?
Bill Pendergrass
ME/AE '82
Old 01-11-2021, 03:32 PM
Gusmax Gusmax is offline
AFP also has a clever purge valve addition that allows you to purge the hot fuel from top of the engine to make for easy hot starts.
Phil Kite
F4 Raider project with RV-8 wings and tail
Old 01-23-2021, 06:59 AM
rockitdoc's Avatar
Ií m going with the Thunderbolt 390EXP119 with AFP injection and dual P mags. Should be a pretty nice setup. Lycoming gives you a $500 credit for the deletion of one mag, so the second Pmag only costs $1000. This makes dual Pmags a $1700 premium over std mags. From strictly spreadsheet logic, if I save 1 gal/hr, it will take about 300 hrs to pay back the investment. Easy decision.
14A
Begun 07-23-20
2021 Dues Paid
Reserved: N52XL
