Old 01-03-2021, 08:49 AM
Bsquared's Avatar
Bsquared Bsquared is offline
Default Heater muffs.....1 or 2
I am half way through phase 1 and I opened the pilot side heater vent for the first time (based in So Cal). It felt like a 2000 watt heat gun pointed directly on my feet! I installed the 2 muffs and plenum that came with my Vetterman exhaust. Do I need both and will I regret it later if I remove 1? Removing the muff on cyl #1 would also solve a scat tube/lower cowl rubbing issue I have been fighting.
RV-14A
S/N 140480
N144BL
Phase 1 complete
Old 01-07-2021, 01:40 PM
Bart Bart is offline
I have the same exhaust equipment - originally installed only one then went back to two because I couldn't keep the scat clear of obstacles.
Old 01-07-2021, 02:57 PM
Bsquared's Avatar
Bart
Any chance you can PM me a picture of your muff installation? Besides it being too warm, I am having an Issue with the scat tube that connects the exhaust of the muff on Cyl #1 to the intake of the one on Cyl #3 rubbing on the lower cowl. I have not found a combination of orientations that works.
RV-14A
S/N 140480
N144BL
Phase 1 complete
Old 01-10-2021, 07:53 AM
Let me see if I have a couple. I'm in phase one now and just recowled it.
Old 01-10-2021, 09:08 AM
Toobuilder's Avatar
Remove muffs, scat tubes and valves; replace with a length of wire and a power jack to plug your heated vest and insoles into. I'm just up the road from you and it works fine for me and my wife.
Michael Robinson
______________
Harmon Rocket II -SDS EFI
RV-8 - SDS CPI
1940 Taylorcraft BL-65
1984 L39C
Old 01-10-2021, 10:17 AM
Bsquared's Avatar
I will have to see what my DAR thinks about that.... his hangar is right around the corner from you
RV-14A
S/N 140480
N144BL
Phase 1 complete
Old 01-10-2021, 10:52 AM
rvbuilder2002's Avatar
Originally Posted by Bsquared View Post
Bart
I donít understand this comment because the SCAT tube that couples the outlet of the front muff to the inlet of the aft muff is only supposed to be about 2 inches long.
The ports on the muffs are meant to be positioned so they are aligned with each other, with the SCAT bridging the gap between them.
Scott McDaniels
Hubbard, Oregon
Old 01-10-2021, 11:48 AM
Bsquared's Avatar
Scott
It may be because I am using a vetterman exhaust and the muffs Clint provided but the outlet of the forward muff is mis-aligned with the rear muff by about 15 deg in 2 plaines. I have to do a ďslinkyĒ arrangement to connect them and this results in the rubbing on the lower cowl. I donít have any pictures to send until I remove the cowl for the next inspection.
RV-14A
S/N 140480
N144BL
Phase 1 complete
Old 01-10-2021, 11:57 PM
Scott
I missed that in your first post but that explains it.
Scott McDaniels
Hubbard, Oregon
Old 01-11-2021, 09:58 AM
KeithB's Avatar
KeithB KeithB is offline
I have a Vetterman exhaust with 2 muffs, but I also have a Superior cold air induction sump, so potentially different. I plumbed my air differently than Vans instructions because of these differences, but Iím happy with the result and do not have cowl interference, though some clearances are close.
Conceptually, from the intake on the ramp, I went through the fuel injection air intake tubes to the back of the sump to a T split, sending intake air to each muff located on separate final exhaust pipes (output of 2-to-1), then each muffís output goes to the separate heater vents.
Vanís installation has muffs in series using heat from 2 of 4 cylinders splitting output air - my installation uses muffs in parallel using heat from 4 of 4 cylinders splitting input air.
Click image for larger version
Keith Brown
RV-14A Builder - kit #136
N314KC - First flight Mar 8, 2017, 24th in the air, >700 hrs
XP-400 Aero Sport Power, replaced with Lyc Thunderbolt 390
RV-6A sold
Sport Pilot (weight-shift control) - Airborne XT912
Dues paid 9/2020
