So as I was building my wing I went ahead and did the work of attaching the aileron doublers detailed in SB 16-3-28 proactively. However the added left small doubler is nearly covering a rivet hole i need to attach the aileron gap fairings.
Below is a pic from the SB with the rivet i'm trying to now add that's giving me touble.
I can insert the rivet just fine, but it's right up against that doubler that when i rivet it, it deforms the shop end. I tried 3 times.![Frown :( :(](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
I'll email Van's but just curious if others have run into the same issue. The SB details the steps need to retrofit the parts, not if doing while building.
I believe a blind rivet will work just fine, but not sure which should be used.
Below are pics from an attempt:
![Screenshot-2021-01-02-192800.jpg](/proxy.php?image=https%3A%2F%2Fwww.rkulesa.com%2Fwp-content%2Fuploads%2F2021%2F01%2FScreenshot-2021-01-02-192800.jpg&hash=92b8dcbc4581d32276f1e437d7200e65)
![IMG_1286-Medium.jpeg](/proxy.php?image=https%3A%2F%2Fwww.rkulesa.com%2Fwp-content%2Fuploads%2F2021%2F01%2FIMG_1286-Medium.jpeg&hash=afe9fff7b3c39058b59bf2addf342979)
![IMG_1285-Medium.jpeg](/proxy.php?image=https%3A%2F%2Fwww.rkulesa.com%2Fwp-content%2Fuploads%2F2021%2F01%2FIMG_1285-Medium.jpeg&hash=618701ad3d61c00e05fb748a77f0f27e)
