“Stretching” Shrink Tubing
HFS
Here’s a little tip when the shrink tube you are trying to use is just a “smidge” to small, but the next size up is too big.
You can (temporarily) “stretch” the tube with needle nose pliers - you have about ten seconds before it revertsView attachment 5806 to its original size.
Another tip is when the hose barb fitting you are trying to install is just a bit to small for a good seal when a clamp is applied. Shrink a piece of the appropriately sized shrink tube over the barb and then finish as usual.
YMMV
HFS
Thanks, but.....
NOW you tell me! :)
I'm sure I could have used the expanded shrink tube tip many times while building.
Thanks for posting
It works even better if you have a pair of needle nose pliers that are really long and skinny. I don't know if that type of pliers has a specific name, but I submit that "shrink tubing stretchers" would be a good name! :rolleyes:
I usually use these:
