Old 11-26-2020, 12:34 PM
bobnoffs bobnoffs is offline
Default quality fuel fittings
so i spend so much time online comparing.........every time i work on fuel,oil systems.
does anyone really know if the brass hose fittings on ,zoro for example , are satisfactory safetywise as a fitting costing 3 times as much at another site.
Bob Noffs
n. wi.
dakota hawk/jab 3300 built and flying. sold 6/18.getting serious about the 12. in the hangar now as of 10/15/19
RV-12 kit as of 9/13
Old 11-26-2020, 06:53 PM
Jpm757 Jpm757 is offline
Bob,
As tempting as it is to use non-aircraft parts on our aircraft, I make every attempt to use aviation grade hardware, fittings, hoses etc: whenever possible. One thing that sets the RV's apart from most EAB aircraft is that the materials, fabrication methods and standards are up to par with most certified aircraft.
Jake
RV6 #20477 completed 1991 sold.
RV7 #72018 N767T first flight 11/21/2017 350+ hrs.
IO-360M1B MT 3 blade, Dual AFS 5600 QUICK Panel.
Manual Flaps. (KOXC)Oxford, CT, (0NY0)North Creek, NY.
1941 J3 Cub skis,floats.
2020 dues gladly paid.
Old 11-26-2020, 07:30 PM
9GT's Avatar
9GT 9GT is offline
This stuff is too important to go with unknown quality to save a few dollars IMHO.
David C.
Howell, MI
"Donor Exempt" but donated through Dec. 2021
