Old 09-22-2020, 06:57 AM
Amazon-1 Amazon-1 is offline
Default Washers - NAS1149F0 vs AN960
OK, I am confused.
In Van's instructions (Section 05-33) it clearly says to NOT substitute a AN960 washer for a NAS1149 washer because the NAS washers are manufactured to a higher tolerance but when I try to buy NAS washers from Spruce they offer the 960 washers instead.
Is this a concern?
thanks,
bruce
Bruce
2003 RV-8, N297NW, bought, flown, sold (~600 hours)
2007 RV-10, N662G, bought, flown, sold (~700 hours)
2020 RV-14A, N662F, built, just finished Phase I
Old 09-22-2020, 08:18 AM
rvbuilder2002's Avatar
The main concern is in situations where the plans call out the use of washers as spacers......
Even though both washer designations are aircraft grade hardware, the NAS part has a much tighter tolerance for thickness than the AN washers have.
This causes a lot of problems when calling out a specific # of washers for an assembly that they are used as spacers in.
So in instances where you are just using a washer for the common purpose of load distribution and abrasion protection AN960's are fine, but NAS should be used when it looks like a specified stack-up is dimensionally sensitive.
Scott McDaniels
Hubbard, Oregon
Old 09-22-2020, 09:38 AM
jacoby jacoby is offline
I measured a couple batches of AN960 (one from ~1983 and one from last year from AS) and the NAS1149 washers supplied by Van's. The AN960s came in consistently 0.002-0.003" undersized at 0.060-0.061". The NAS1149 were 0.0063-0.0064". n=5 from each batch.
Interestingly I also have mixed in with the old batch of AN960s some washers that have a silver-colored plating (nickel?) and match the NAS washer thickness.
Old 09-28-2020, 12:40 PM
Fly2eat Fly2eat is offline
Hi Scott,
I'm trying to cross reference the 5702-75-060 and 5702-95-30 washers and it appears this may be a Vans part number. Is there a better part number to cross reference? I have a big order going to Spruce for other stuff and wanted to include those. It calls for them on the RV-4 blueprints on drawing 28.
L. D.
L. D. Jeffries
RV-8 N65KJ "Fifinella"
Building RV-4 #2593
Poplar Grove, IL (C77)
603-491-4175
ldjeffries@gmail.com
Old 09-28-2020, 01:22 PM
RV7A Flyer's Avatar
Originally Posted by Fly2eat View Post
Hi Scott,
L. D.
I think someone figured out years ago those aren't *actually* "washers" in the AN/NAS sense...they're *spacers*.
2019 Dues paid!
Old 01-10-2021, 07:35 PM
HAL Pilot's Avatar
HAL Pilot HAL Pilot is offline
Would it make sense to use stainless washers on the aileron and flap hinges?
Pete
RV14A Tail kit 95%
Wing kit 95%
Fuselage QB stuck in China virus corrosion purgatory
RV 14 WIKI in Drop Box
https://www.dropbox.com/sh/xu5p6f4l7...bU0ck0pJa?dl=0
please purchase the thumb drive Vans offers. I DO NOT want to take away from sales flow or get the WIKI Killed.
---For Edit Access drop me a PM with your Email address.
EAA 1300
Donation Paid 18,19,20,21 Military exempt
