Old 06-25-2020, 05:24 PM
RV701775 RV701775 is offline
Default Rib Flange Faceting
I am struggling with how to shape-deburr the nose of the rib flanges. Even if I remove only a little bit to shape the nose section, the rib radius becomes very thin. How do others accomplish this? Any photos?
Here are mine: https://photos.app.goo.gl/oUJwjLLVSPP6y8NFA
Old 06-25-2020, 05:40 PM
wirejock's Avatar
wirejock wirejock is offline
Default Ribs
That looks fine. I don't remember filing any down unless they were causing a problem. I remember the tank ribs needed some love.
Helps to tell us what component. Maybe I missed it.
Larry Larson
Estes Park, CO
wirejock at yahoo dot com
Donated 12/01/2021, plus a little extra.
RV-7A #73391, N511RV reserved (3,000+ hours)
Empennage, wings, fuse, finishing kit done. Working FWF
Disclaimer
Old 06-25-2020, 06:08 PM
It was the top rib on the VS. I am about to do the bottom nose rib, so I wanted to double check.
Old 06-25-2020, 07:07 PM
wirejock's Avatar
Default VS rib
Ahhh. I still think it's good but watch closely as you cleko to be sure it doesn't make a crease (outie) in the skin. Bottom rib is less prone but always check.
Larry Larson
Estes Park, CO
Disclaimer
Old 06-25-2020, 07:37 PM
vlittle's Avatar
vlittle vlittle is offline
Advice I received from Gus Fennell when he was at Vans:
Use a disc sander to provide a smooth curve around the nose of the ribs. This will thin them out in some areas, but will allow the skin to fit smoothly. Not a structural issue.
V
V e r n. ====
RV-9A complete
Harmon Rocket complete
Part of EAA award-winning OnSpeed team
The VV in huVVer.tech
Victoria, BC (Summer)
Chandler, Az (Winter)
