Old 06-25-2020, 12:19 PM
oren_rokach oren_rokach is offline
Default Panel layout review / comments
Hello Guys
Can you please review my panel design?
comments on layout and locations ?
https://photos.app.goo.gl/WRWYZ4nJ3uAvEys97
and 3D:
https://photos.app.goo.gl/rpNc1j18DW7YS8b17
Its a VFR panel,
the GMC507 AP and GNC 255a com , will be located below the panel
Thanks !
Oren
Oren Rokach
4X-ODU
RV-10 QB
Blog:
https://4x-odu.blogspot.com/
Old 06-25-2020, 12:39 PM
terrye terrye is offline
Your Alt Air and Cabin Heat knobs may interfere with the forward co-pilot stick position when they are pulled out.
Terry Edwards
RV-9A (Fuselage)
2021/2022 VAF Contribution Sent
Old 06-25-2020, 02:48 PM
Thanks !
Must admit, i didn't notice it.
I went back to my osh flight in the Van's RV10
and it seems like same location.
https://photos.app.goo.gl/Lq7E6GEfpKsdv7re6
I wonder if its interfering in anyway....
Oren Rokach
4X-ODU
RV-10 QB
Blog:
Old 06-25-2020, 03:17 PM
Desert Rat Desert Rat is offline
why 2 start buttons?
Terry Shortt
AGI, CFI, CFII, MEI, A&P, Janitor
RV7 Empennage & Wing done
Fuselage in process
#72651
https://eaabuilderslog.org/?blprojec...t=all&listcat=
Old 06-25-2020, 05:29 PM
Originally Posted by oren_rokach View Post
Thanks !
On my -10 the stick almost passes below the panel, and does pass below the heat controls (same location as yours). Depends on your choice of stick grips and if you cut the stick down, and how much. You do need to watch out for the alt air and mixture controls at full forward and full right/left, respectively.
Old 06-25-2020, 10:08 PM
beav's Avatar
beav beav is offline
Default Switches
Can you post a picture that includes switch labels? I'm a little concerned that all of your switches are in one row with no spaces between.
You're very likely to end up with one switch that should remain on during flight and one that you toggle during flight. With no space between them, it's fairly easy to accidentally flip the wrong one.
jason
N4VR
RV-7 (Flying)
http://www.jasonbeaver.com/rv7
Old 06-25-2020, 10:53 PM
Basically one for pilot, one for co-pilot.
In case of engine cut, one can fly the plane , other can focus on engine start
Oren Rokach
4X-ODU
RV-10 QB
Blog:
Old 06-25-2020, 10:57 PM
AVI MSTR
AVI BATT (TCW backup)
pitot heat
defrost fan
AP on /off
landing lt
taxi lt
nav lt
stobe lights
Wig wag
fuel pump
Thanks for the note, makes sense!
Aesthetics come first, practical second. no?
Will try and reorganize to give some spacing!
Oren Rokach
4X-ODU
RV-10 QB
Blog:
Old 06-26-2020, 07:23 AM
fl-mike's Avatar
fl-mike fl-mike is offline
Pitch and roll indicators are reversed, but not needed. The G3X can show trim positions.
Mike W
Venice, FL
N164WM
N184P reserved (RV-8QB)
Old 06-26-2020, 08:56 AM
rcoleman-10 rcoleman-10 is offline
Panel looks great. Efficient. Since you are in the process of building up your panel I would add a PTT (for Comms) on the upper left and right side of the panel. It will keep your hands free from messing with the stick while on auto-pilot. I know if sounds trivial but you will really like it.
Ron
3T5
