Old 06-20-2020, 10:24 AM
jcarne's Avatar
jcarne jcarne is offline
Default Can someone tell me how Van's does this MAP line?
Hello, I pulled this pic from Van's 360 view of the RV-14 engine.
I want to do my manifold pressure line just like they did. It looks like the line is just hose clamped on the left to the MAP sensor but what did they do on the right where it attaches to the engine? I have an AN816 coming out right there, do they just hose clamp the line to it?
Finally, what type of hose is that? Thanks!
1 by Jereme Carne, on Flickr
Jereme Carne
PPL
RV-7A Flying as of 03/2021
Old 06-20-2020, 11:13 AM
rvbuilder2002's Avatar
AN840-4D
1/4 ID fuel rated hose
Fitting should have a restrictor added to it if you make your own.
Scott McDaniels
Hubbard, Oregon
FAA/DAR
Old 06-20-2020, 12:04 PM
jcarne's Avatar
AN840-4D
Scott, do you know if you guys sell one with the restrictor in it? This fitting does not appear to be on the M1B firewall forward list for the RV-7. I'm assuming this is a standard part on the -14. Also, is the Aeroquip hose what you are referring to? Just trying to figure out what I need to order from you guys. Thanks for the help!
Jereme Carne
PPL
Old 06-20-2020, 12:31 PM
wjb's Avatar
wjb wjb is offline
I added my MAP sensor to the three port manifold that also holds the oil and fuel pressure sensors on the firewall. TS Flightlines built a hose for me with a 90 degree fitting for connecting to #4 primer port and put a 45 deg restrictor fitting at the entry to the manifold block. Seemed to me to be the easiest way to mount the sensor.
Bill Bencze
N430WB RV-7 @KHAF, Flying 100+ hrs
VAF 2022 donation happily made
Old 06-20-2020, 02:30 PM
RV6_flyer's Avatar
I am not Scott but yes they sell the restrictor fitting.
Any fuel / oil hose the correct size will work as long as it has the correct fitting on the ends if a fitting is necessary.
Van's sells a VA-119 manifold pressure hose but it may or not not work with the MAP gauge that you are using.
Gary A. Sobek
NC25 RV-6
Flying
3,500+ hours
Where is N157GS
Building RV-8 S/N: 80012
Old 06-20-2020, 04:26 PM
Ed_Wischmeyer's Avatar
Ed_Wischmeyer Ed_Wischmeyer is offline
On my RV-9A with Garmin G3X Touch, there is considerable lag in the manifold pressure reading when changing the throttle, and the reading does not settle down to a steady state once the throttle is fixed but wanders. I'm wondering if the tube is too long between the manifold and the sensor.
Any ideas?
Thanks!
Ed
RV-9A at KSAV (Savannah, GA; dual G3X Touch with autopilot, GTN650, GTX330ES, GDL52 ADSB-In)
Previously RV-4, RV-8, RV-8A, AirCam, Cessna 175
ATP CFII PhD, so I have no excuses when I screw up
Vaccines kept me out of the hospital but COVID still cost me a month of living, all told...
Old 06-20-2020, 05:59 PM
Jereme, the Dynon MAP sensor has a tube stub. So if you use the rubber hose, push it Make a restrictor for the AN840 tube for the #3 cylinder.
Those with teflon hoses and crimped AN hose ends---the restrictor fitting is a no brainer. On the Dynon, side, you can take a short piece of Aeroquip 306-4 and push a male AN fitting in it, and clamp to it and the hose to the Dynon sender.
Tom
RV7A Tail Kit Completed, Fuse started-Pay as I go Plan, on hold while we develop new products for RV builders
Ridgeland, SC
Old 06-20-2020, 09:34 PM
jcarne's Avatar
Ya that fitting is very different than an AN840. I got some of those for my pressure takoffs on fuel/oil but it won't work with this setup unless I go with a flared hose. Something I was trying to avoid just based on cost.
Tom
Thanks Tom. Thanks for the email as well. A bit to ponder now.
Jereme Carne
PPL
Old 06-21-2020, 12:12 AM
jcarne's Avatar
For anyone else searching this in the future. I found a Van's document here that outlines the parts and steps to install this on the -14.
After much searching the hose part number is EA Hose H175 but is referred to on the -14 install as FF-00008. You can also get the clamps which are part number FF-00010. The hose is 1/4" fuel line like Scott mentioned and appears to be Gates PVC/EEC rated to +257 degrees Fahrenheit.
Jereme Carne
PPL
Old 06-21-2020, 09:45 AM
Aircraft Specialty Aircraft Specialty is offline
Tom
As Tom mentioned, it is very easy to adapt to a Dynon MAP with a Teflon hose setup.
In our FWF hose kits, we manufacture a MAP adapter for builders with DYNON avionics. Shown below is an integral Firesleeve FWF hose package with the DYNON MAP hose and adapter. (This is not for an RV). The AN flare side hooks up to a restrictor fitting that is screwed into the engine.
We build a lot of FWF hose kits for the the RV14. Shown below is how you can easily adapt a PMAG setup for the RV14 with a DYNON MAP. The teflon hose connects to a restrictor fitting in the engine. That runs to an AN TEE which splits the line. One end goes toward the single or dual pmags, while the other end connects to the DYNON adapter we manufacture for the MAP hook up.
Steve Tschurwald- Aircraft Specialty LLC (Your source for Custom Parts for Experimental Aircraft), AS FLIGHTLINES (Joint Venture with TS Flightlines)
aircraftspecialty@gmail.com
www.aircraftspecialty.com
www.asflightlines.com
