Old 06-08-2020, 08:42 PM
gharding gharding is offline
Default ADS-B NO RADAR
Can anyone tell me what the message “ADS-B NO RADAR means? I am seeing this on my Dynon Skyview HDX, in the lower right hand corner of the map.
http://halie.com/scale/20/oDH.jpg
Gary
Old 06-09-2020, 08:54 AM
GalinHdz's Avatar
GalinHdz GalinHdz is offline
Good question. I have asked the question on the DYNON forum to hear from them.
Galin
CP-ASEL-AMEL-IR
FCC Radiotelephone (PG) with Radar Endorsement
2021 Donation made
www.PuertoRicoFlyer.com
Skysailor Skysailor is offline
I have that on mine. I do not use the Dynon transponder which is why it is displayed per tech support. Do you also have an "other than Dynon" transponder? If so, yours is just like mine. It only has to do with traffic and not being able to as easily eliminate own ship. It does not affect the display of weather. All the weather displays work correctly.
RV4
Old 06-09-2020, 09:19 AM
bkervaski's Avatar
bkervaski bkervaski is offline
He's getting intermittent traffic, even from air to air.
I met up with him from about 5 miles away Saturday and never showed up as an alert or otherwise on his ADSB.
However, he is broadcasting, I picked him up no problem.
New to him 14 from the west coast, Synergy build.
RV-14A #140376
N196 (Flying)
2019 Bronze Lindy
Old 06-09-2020, 09:24 AM
DHeal DHeal is offline
See Page 5-28 of: https://www.dynonavionics.com/includ...ev_E_v15_4.pdf
David Heal - Windsor, CA (near Santa Rosa)
EAA #23982 (circa 1965) - EAA Technical Counselor and Flight Advisor; CFI - A&I
RV-12 E-LSA #120496 (SV w/ AP and ADS-B 2020) - N124DH flying since March 2014 - 1,080+ hours (as of Oct 2021)!
VAF donation through June 2022.
Old 06-09-2020, 11:01 AM
N804RV's Avatar
N804RV N804RV is offline
This is what @skysailor is talking about:
Ken W.
Mount Vernon, WA
2021 VAF Supporter
Old 06-09-2020, 11:37 AM
RV7A Flyer's Avatar
The ground-basedADS-B system is reporting that it does not have your airplane in radar contact, or that your system is not seeing the ground station reporting your airplane is in radar contact. Although you are receiving ADS-B traffic from other ADS-B equipped aircraft, you may not be receiving all detectable traffic because you maynot be currently in a radar service volume and ADS-B service volume. Therefore, the traffic portrait may be incomplete.
Yep, this is directly from the Skyview User's Manual.
Imagine that.
2019 Dues paid!
Old 06-09-2020, 11:45 AM
I do have the Dynon SV-XPNDR-261/262 Dual Band ADS-B transponder system installed in my RV-14. It may be a system setup issue that I am unfamiliar with. I do have a call into Dynon Avionics Tech Support for another issue and will post what I find out from them. Thanks for your response.
Gary
Old 06-09-2020, 08:29 PM
RVDan RVDan is offline
Re: NO RADAR- I believe it means no weather radar data.
Dan Morris
Frederick, MD
PA28-140
Hph 304CZ
RV6 built and sold
N199EC RV6A flying
Retired Aerospace Engineer and A&P/IA
Old 06-10-2020, 10:06 AM
lon@carolon.net lon@carolon.net is offline
Is the ?No Radar? alert always showing, or is it intermittent? If it?s intermittent, it may mean that you?ve flown into an area that radar does not reach. In the Los Angeles area, I get ?No Radar? when flying in the area around Camarillo, but the alert goes away when I get closer to Santa Monica.
Lon Sobel
Santa Monica, CA
VAF 2021 Dues Paid
