Keep VAF
Going
VAF on Twitter:
@VansAirForceNet
06-04-2020, 07:40 PM
AN470 AD 6-5 rivet/ tank rib sub assembly
The plans below call for a 6-5 rivet though the kit only includes 6-6?s. My first attempt at setting this rivet was with the DDRT dimpler. The first rivet set went good, the second was a disaster. The plans call for using a C-frame, that might have helped had I owned one.
As I understand, this large rivet is only there to fill a hole and requires only enough squeezing ? to retain the rivet in the hole?.
I presume that to mean as long as the rivet doesn?t turn and doesn?t fall out it?s good to go.
Anyhow- is there an effective method to facilitate setting this large rivet without a c-frame?
In lieu of no other direction, My plan tomorrow is to put a slight squeeze on the rivet with my DDRT or tap it with a bucking gun and rivet set, if I have one large enough to fit this big honking rivet.
RV14 Empenage complete
Wings in work
Dues bypass eligible- paid anyhow
06-05-2020, 06:42 AM
I set those with rivet gun / bucking bar.
Dennis Callaghan (X26)
- RV14 sn:140193 - Awesome airplane!
- donation 11/17/2022
06-05-2020, 06:47 AM
This can be achieved with the correct size set and a Yoke in the hand squeezer.
The pneumatic squeezer struggles to set AD6's
It will take a few squeezes and adjustments to get it to set
Remember to use a bit of pro seal under the rivet head
06-05-2020, 07:59 AM
Two very good ideas. I may try both methods.
Thanks.jt
Wings in work
06-05-2020, 09:29 AM
FWIW, on my -10, a local builder gave me some 470A-6-? (soft) rivets that I cut down to the -5 length. They set easily and quickly with the gun. -6 length is too long since you are just going through the one skin. I would trim one to -5 length if possible, especially since you are using AD rivets, and see how it set. 1/16" makes a pretty big difference.
And, yeah, you are just trying to fill the tooling holes.
06-05-2020, 10:11 AM
#6 rivet
I put my bar in the vise so the base was firmly planted on the vise frame. Set the rivet with a gun. It just filling the tooling hole. As long as it doesn't rattle, slop some proseal over it and call it good.
Larry Larson
Estes Park, CO
E-mail: wirejock at yahoo dot com
Builder Blog: http://wirejockrv7a.blogspot.com
Donated 12/2022, plus a little extra.
RV-7A #73391, N511RV reserved
Disclaimer
06-05-2020, 10:21 AM
Can a cherry max be used here?
06-05-2020, 11:51 AM
Pop rivet
No need for a structural rivet. It's just plugging a tooling hole. Find a pop rivet the right size. I recommend the factory head on the inside of the tank.
Larry Larson
Estes Park, CO
Disclaimer
06-05-2020, 12:07 PM
another option
I riveted a square patch over the hole when I built my tanks, didn't have any 470-6 rivets.
mangling aluminum since May 2009
RV7-A, flying
RV8 under construction
06-05-2020, 03:24 PM
I set those with a rivet gun in the C-frame. Easy-peasy.
Ken
RV-8 N118KB (#81125) - Sold
RV-14A N114KB (#140494) - Sold
RV-14A.com
N114KB Build Site
Thread Tools |
Search this Thread |
Display Modes |
Linear Mode
