Old 05-31-2020, 08:41 AM
RV701775 RV701775 is offline
Default Skin Deburring Question
On skins and other punched parts where there are curves or bends in the punched area there are significant burrs on each side of the curve that I am finding difficult to debur without taking off quite a bit of material from areas around the curve. If I use a flat needle file it leaves a notch that could create a stress concentration, so I have been using a curved needle file but it is necessary to increase the radius to maintain a well curved surface. This creates a slight hump. I wanted to get some feedback and possibly some photos or examples of how other handle these areas.
Here are my photos:
https://eaabuilderslog.org/?blprojec...=7YL1dRvO9&add
Old 05-31-2020, 09:09 AM
jcarne's Avatar
jcarne jcarne is offline
I used little scotchbrite wheels from Cleaveland on a Dremel to get things like that. If it was really tight I used 400 grit turners cloth and flossed it.
Jereme Carne
PPL
RV-7A Flying as of 03/2021
Old 05-31-2020, 09:38 AM
Marc Bourget Marc Bourget is offline
Have you tried a drill slightly larger than the hole, and roll it between two fingers as you rock it back and forth?
Sharp drill won't require much pressure. A finger from the other hand near the tip helps direct the deburring.
Old 05-31-2020, 05:36 PM
wirejock's Avatar
wirejock wirejock is offline
Default Corner deburring
Don't overthink it. Wrap a piece of maroon scotchbrite around a piece of PVC pipe and roll it in the corner.
Larry Larson
Estes Park, CO
wirejock at yahoo dot com
Donated 12/01/2021, plus a little extra.
RV-7A #73391, N511RV reserved (3,000+ hours)
Empennage, wings, fuse, finishing kit done. Working FWF
Disclaimer
Old 05-31-2020, 06:03 PM
fl-mike's Avatar
fl-mike fl-mike is offline
Files, needle files, drill bits, deburring tool, abrasive cloth, 400 grit aluminum oxide sandpaper, scothbrite wheels, a bit of scotchbrite cloth on an arbor. Whatever it takes. Trust me, you'll have a drawer full of options soon...
Mike W
Venice, FL
N164WM
N184P reserved (RV-8QB)
Old 05-31-2020, 06:07 PM
mturnerb mturnerb is offline
I'll add a couple to this list: emery cloth (may be the same as abrasive cloth and if so, I'm being redundant), and these little goodies: https://www.amazon.com/Mitchell-Abra...0966346&sr=8-4. (comes in various sizes).
Also - sandpaper rolled up into little cigarette-sized rolls, and adhesive sandpaper (https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1) on a popsicle stick....
Turner Billingsley
RV-14A built/sold N14VB
Old 05-31-2020, 11:48 PM
JonJay's Avatar
JonJay JonJay is offline
Hand deburring tool is another option. They work great on larger radius holes and inside corners. I prefer it over using an abrasive for short run work in these areas. The end result can be just as smooth as polishing once you learn the right pressure and angle and how to steady the tool.
RV6 - Builder/Flying
Bucker Jungmann
RV1 - Proud Pilot.
Old 06-01-2020, 07:54 PM
Aero_Octaveus Aero_Octaveus is offline
1" squares cut out of maroon scotchbrite, then attached to the end of a dremel does an incredible job of smoothing out those nooks and crannies after you use a small file to break the edges.
Amazon is also a gold mine when it comes to small sanding drums for the dremel as well.
Garet Hess - Edmonton, AB
RV-7A - Emp and Wings Done. Working on fuse
2021 Donation Current
http://garetsrv.blogspot.ca/
Old 06-01-2020, 10:57 PM
DTARM1 DTARM1 is offline
You don't need a machine. I don't know why so many people need to have some kind of machine to do something. Hold a piece of sandpaper or scotchbrite in your hand and using your finger rub the piece of sandpaper or scotchbrite across the area to deburr. You don't need a $3,000 scroll air compressor and a $1,500 Desouter angle grinder with a $15 3M rol loc and a $4 rol loc disc to do what a piece of scrap sandpaper you pull out of the trash can will do. But, then again, maybe you do.
Old 06-02-2020, 06:53 PM
bk1bennett's Avatar
bk1bennett bk1bennett is offline
He speaks truth
Latest Donation Dates: Jan 2022
RV-14A Empennage Kit #140396
