Old 05-19-2020, 07:36 PM
greghughespdx's Avatar
Default Weight and balance limits adjusted for RV-6/6A/7A/9A
We've published a handful of updates related to weight limits on the RV-6/6A/7A/9A aircraft.
Change to Max Recommended Gross Weight for RV-6 (taildragger only)
The first published change is to RV-6/6A Manual Section 14 (Weight & Balance). The change raises the recommended max gross weight for the RV-6 to 1650 pounds (this is a 50-pound increase and is now the same max gross weight as the RV-6A). Previously the RV-6 recommended max gross weight had been published at 1600 pounds. The RV-6/6A aerobatic limit (1375 pounds) does not change.
Why were these numbers different in the first place? When the RV-6A was created (after the RV-6 was already available), the structure was tested to a higher value to accommodate the slightly-heavier airplane. Structurally the two models are essentially the same from a max gross weight perspective. We are issuing this change to reflect that fact. And yes, we do realize it's been 35 years.
Removal of Nose Wheel Weight Limit on RV-6A/7A/9A with U-00019 Type Nose Gear
In addition, the max nosewheel weight for the RV-6A/7A/9A has been removed for aircraft where the new-style U-00019 nose gear leg (released in 2019) and engine mount are installed. In that case, the weight limits are instead determined using the aircraft’s overall weight and balance envelope. The new design was specifically tested prior to release around a worst-case forward CG loading scenario, and it was determined no limit is necessary other than the standard W&B envelope boundaries. We stated this year with the release but did not update Section 14 of the plans for each airplane, so we are formalizing that now.
The relevant documents are linked below:
Greg Hughes - Van's Aircraft
Building RV-8A since Sept 2014
Aurora, OR (EAA Chapter 105)
Old 05-20-2020, 01:05 AM
Dan 57's Avatar
Dan 57 Dan 57 is offline
Thumbs up Vans, thanks
Life's short... Enjoy!
http://www.aerofun.ch
RV-6.9 #25685, slider, O-360-A3A (carb/dual Lightspeed II), MTV-12-B, HB-YLL owner & lover
RV-4 #2062 HB-YVZ airframe builder
Old 05-20-2020, 09:46 AM
Snowflake's Avatar
Good to know! Now to figure out how to get Transport Canada to allow the increase...
Rob Prior
Old 05-20-2020, 03:14 PM
Jpm757's Avatar
Jpm757 Jpm757 is offline
For aircraft certified at #1600, I would imagine that one would need to re-enter phase 1 testing for some period of time to get the FAA to sign off on the gross weight increase. If Van's made this gross weight increase a "Service Bulletin" could that possibly allow for the increase with out having to jump through the paperwork hoops?
Jake
RV6 #20477 completed 1991 sold.
RV7 #72018 N767T first flight 11/21/2017
(KOXC)Oxford, CT, (0NY0)North Creek, NY.
1941 J3 Cub skis, floats.
Building Javron Super Cub.
2020 dues gladly paid.
Old 05-20-2020, 03:29 PM
N941WR's Avatar
N941WR N941WR is offline
When are you going to raise the GW for the -9 to 1800 lbs and bless the parallel valve (I)O-360 in it, as long as the existing V speeds are observed?
You had to know someone was going to ask that question.
Bill R.
O-360 w/ dual P-mags
SC86 - Easley, SC
www.repucci.com/bill/baf.html
Old 05-20-2020, 05:22 PM
No, a SB wouldn't change the requirements. Gross weight change is considered a major change, so what is required for your airplane to make it legal will depend on your airplane's specific Op Limits. Joe Norris wrote a good article on this a while back. Questions (and directions) are probably something to deal with your local DAR or FSDO on. Im my experience, some handle these sorts of changes differently than others (unfortunately). But your op limits should spell out what's required for a major change.
Old 05-20-2020, 05:51 PM
Originally Posted by N941WR View Post
When are you going to raise the GW for the -9 to 1800 lbs ... You had to know someone was going to ask that question.
Hah, of course.
The RV-9/9A gross weight won't change. That is a function of the wing structural design. remember that the RV-9 is designed to operate in the +4.4G utility category, where the 6/7/8 are designed to the +6G aerobatic category. The high-lift wing on the RV-9 is a great wing for a specific purpose (high-efficiency and performance at altitude), but it simply doesn't have the same loading capacity as the aero models, and gust loading factors on the -9 wing airfoil are quite different than on the others, as well.
... and bless the parallel valve (I)O-360 in it, as long as the existing V speeds are observed?
We have not finished that analysis yet.
Old 05-21-2020, 12:01 PM
airguy's Avatar
airguy airguy is offline
Really? [blinks back tears, sniffs twice] The church might actually take me back? They still love me?
Garden City, TX VAF 2021 dues paid
N16GN flying 900 hrs and counting; IO360, SDS, WWRV200, Dynon HDX, IFD440, G5
Old 05-21-2020, 01:07 PM
JonJay's Avatar
JonJay JonJay is offline
My 6 will no longer be considered “grossed up” as I set the 1650# limit in the OP’s before she flew thirteen years ago. Me, wifey, 26g fuel, 100# baggage = 1650#.
Yay! (Although I was never worried about it.)
Thx Greg.
RV6 - Builder/Flying
Bucker Jungmann
RV1 - Proud Pilot.
Old 05-21-2020, 05:25 PM
elev666 elev666 is offline
Why thank you Greg, that Ups my useful load by close to 10%! But as Rob Says i'll likely have to give Transport my last born ,,, wait a minute she?s not done school yet , I?ll call them tomorrow,
RV 6. GARV
1946 C85 J3
RV 7 A project
Grounds keeper @ CKS9, 2021 dues pd
Garry
