Go Back   VAF Forums > Model Specific > RV-14
Old 05-13-2020, 07:18 PM
Jarrett Jarrett is offline
Default Vertical Stabilizer Forward Spar
Just started working on my 14A empennage and I seem to of already made a mistake... I was match drilling the reinforcement plate to the forward spar and I got to the hole that was supposed to be match drilled to 1/4 inch. Through my reading I've read that for bigger holes it is best to use a unibit to avoid the metal catching and hole distortion. I ended up going too far resulting in the reinforcement plate being chamfered, and the hole on the spar being distorted. Starting to question my choice on using the unibit... Is there anyway to fix/adapt or should I order new parts?
Photos:
https://photos.app.goo.gl/GXVsUT1sHk1Wo5qb9
https://photos.app.goo.gl/qjZohtb7v9Mdw6iw6
Jarrett
Old 05-13-2020, 07:41 PM
Allan Stern Allan Stern is online now
Default Vertical stab reinforcement plate
If a 1/4 plate nut is attached on the otherside of that hole so a heim joint is screwed throuh it it should't be a problem. If you wanted to clean it up a bit you could use unibit to go one size larger. Call support at van's and double check.
RV 14A flying phase 1in progress
RV 6A flying sold
RV 8A flying sold
RV 12 flying
Old 05-13-2020, 07:43 PM
PaulvS's Avatar
PaulvS PaulvS is offline
Default Drilling
A normal good quality jobber drill bit should be fine for a 1/4 inch hole like that. Not sure if you are using a drill press? (recommend)
Unibits are not without their risks as it is easy to accidentally go oversize to the next step up especially in thicker material.
As for the hole in the pictures, I'm not familiar with the -14 but assume the hole is for a nut plate and if so I think it should be OK once deburred. If you want to clean up the hole itself then I suggest careful use of a 1/4 inch chainsaw file, you only want the hole smooth and not bigger.
Paul vS (yes I'm also a Van)
Building RV-6A #22320 O-320 FP. Wings and tail complete, working on fuselage
Flying my Aeroprakt A-22 STOL and the aero club's RV-9A while I build
Old 05-13-2020, 08:21 PM
Thanks for the help guys. I have a drill press and when I was drilling this hole I was not using it. Pretty sure once I went through the material it jump through and I drilled too far... I will definetly be using the drill press next time! I'll give a call to tech support tomorrow and see if I can go slightly bigger or I can touch up the hole. First time posting here so thanks for the support, really appreciated!
Jarrett
Old 05-13-2020, 09:34 PM
Jake14 Jake14 is offline
that looks like the mounting hole for the vert stab to the fuselage (see p 11-8 fig 1) and the bolt through that hole is held on with a castle nut to allow for movement between the spar and fuselage (the faying surfaces are lubed per step 1 on 11-8). It probably should be a snug fit, but see what Vans recommends.
RV-14A flying 520 hrs
Old 05-14-2020, 04:51 AM
Jetmart's Avatar
Jetmart Jetmart is offline
When using a unibit I always put a piece of green masking tape around the entire bit on the top of the diameter I am drilling to. It is a great visual to know when to stop drilling.
Glenn Martin
Windsor, Ontario
1942 Tiger Moth
2017 Waco YMF-5
RV-14 Kit # 140694
First Flight - June 22, 2021
2021 Dues Paid
Old 05-14-2020, 07:11 AM
JHartline JHartline is offline
Might be able to just upsize it to an AN-5 and AN310-5. Calling Vans will answer that. As others have said, use unibits with care...they can cause things just like this very easily. I mark the next step with a Sharpie all the way around and drill (with a drill press) to the line.
James Hartline
Carrollton, GA 5GA2
RV-14 - First flight 4/7/2019. Phase I complete as of 9/11/2019!!
Old 05-14-2020, 08:15 PM
Thanks for the tips, I will definitely be marking the steps on my unibit. Just got off the phone with Van's and they said the best thing to do would be to reorder the reinforcement plate as it's a very cheap part and the size needs to be 1/4 inch. Thanks!
Old 05-14-2020, 10:43 PM
JDA_BTR JDA_BTR is offline
I found that my drill press was too fast the first few times I used a Unibit. When I slowed it down <300 RPM the hole quality was excellent and I didn't end up running into the next step ever.
For 1/4" it is worth the investment to get a reamer from ACS or Cleaveland. Drill a hole slightly smaller than 1/4 the regular way, then let the reamer make a perfect hole. Has been very handy for me; I use #40 and #30 reamers all the time in finish drilling as they leave a lot less burr.
Ser 140142, RV-14A flying - N1463
Ser 83825, RV-8 building - N8638?
USN Ret, Urologist, AME, Repeat Offender
Old 05-15-2020, 12:53 AM
eliasj7 eliasj7 is offline
I purchased reamers also. Fair priced at Aircraft Tool Supply.
