Old 05-13-2020, 11:42 AM
Raymo's Avatar
Raymo Raymo is offline
Default Steinair panel switch cheat sheet
This won't cover all the bases but should help with panel planning for many. Compiled during a recent RV-7A panel build. The color column is for the rubber switch cover/boot, also sold by Steinair.
EDIT: 6 Aug 2020: Update to correct the cowl flap switch.
Ray
RV-7A - Slider - N495KL - First flt 27 Jan 17
O-360-A4M w/ AFP FM-150 FI, Dual PMags, Vetterman Trombone Exh, SkyTech starter, BandC Alt (PP failed after 226 hrs)
Catto 3 blade NLE, FlightLines Interior, James cowl, plenum & intake, Anti-Splat -14 seat mod and nose gear support
All lines by TSFlightLines (aka Hoser)
Old 05-13-2020, 11:54 AM
mfleming's Avatar
mfleming mfleming is offline
Thumbs up
Thanks, just started planning for panel switches. Very timely
Michael Fleming
Joseph, OR
sagriver at icloud dot com
RV-7 Slider #74572
Started 11/2016
Empennage completed 11/2016 (sans fiberglass)
Ailerons and flaps completed 3/2017.
Wings completed 12/2017
Started on QB fuselage 01/2018
Sliding canopy mostly completed 10/2020
Wiring and Avionics harness completed 9/2/2021
FWF Started 9/3/2021
Donated for 2021 and so should you
Old 05-14-2020, 12:44 AM
oren_rokach oren_rokach is offline
Any Idea why DPDT is required?
Isn't SPDT suitable for flaps? https://www.digikey.com/product-deta...197-ND/1248727
Oren Rokach
4X-ODU
RV-10 QB
Blog:
https://4x-odu.blogspot.com/
Old 05-14-2020, 07:50 AM
cajunwings cajunwings is offline
Originally Posted by Raymo View Post
This won't cover all the bases but should help with panel planning for many. Compiled during a recent RV-7A panel build. The color column is for the rubber switch cover, also sold by Steinair.
Thanks Ray.
Don Broussard
RV9 Rebuild in Progress
57 Pacer
Old 05-14-2020, 08:27 AM
Desert Rat Desert Rat is offline
Im not there yet on my RV, but assuming that if it's like most of the stuff I've worked on over the years, it's so you can reverse polarity on the motor to make it run both directions.
I remember my first semester in A&P school I asked how this worked (electric cowl flaps on the back of a C-337!) and my basic electricity instructor sketched it out on the little spiral bound notebook he carried around in his shirt pocket. Do they even make those anymore?
Terry Shortt
AGI, CFI, CFII, MEI, A&P, Janitor
RV7 Empennage & Wing done
Fuselage in process
#72651
https://eaabuilderslog.org/?blprojec...t=all&listcat=
Old 08-06-2020, 12:26 PM
Raymo's Avatar
Updated original post with correction.
Ray
Old 08-06-2020, 04:53 PM
Pdtofly Pdtofly is offline
Default It is a DPDT switch
You need a DPDT switch as your flap motor wires go to the center lug on the switch. What you do is cross the outside lugs, so you just change the polarity on the center lugs to change direction of the motor.
Brian
