Go Back   VAF Forums > Avionics / Interiors / Fiberglass > Glass Cockpit
Old 05-06-2020, 01:01 PM
dynonsupport's Avatar
dynonsupport dynonsupport is offline
Default Dynon/Advanced Service Bulletin - Kavlico Pressure Sensors
As an organization of engineers and pilots, we at Dynon and Advanced aim to promote safety-enhancing technology, and we constantly monitor our fleet and support data for issues that arise. To that end, Dynon and Advanced have been investigating a rare but important issue that affects the Kavlico pressure sensors that are often installed in aircraft equipped with our products, and we want to ensure that this community is aware of it.
Although we don't yet have all of the answers, we're publishing what we know, asking you for your assistance and reports, and will have a product improvement that will be available for most applications in the coming days.
We'll let the bulletin speak for itself, as it has the comprehensive background, technical information, and steps for Dynon and Advanced customers to take. Please read the bulletins available here (the content is identical):
https://dynonavionics.com/bulletins/support_bulletin_050620E.php
https://www.advancedflightsystems.com/service-bulletin-050620a.php
_______________________
Dynon Avionics
support@dynonavionics.com
425-402-0433
www.DynonAvionics.com
Old 05-06-2020, 01:15 PM
Mike S's Avatar
Mike S Mike S is offline
Senior Curmudgeon
Good on you for taking proactive action on this.
Mike Starkey
VAF 909
Rv-10, N210LM.
Flying as of 12/4/2010
Phase 1 done, 2/4/2011
Old 05-06-2020, 04:19 PM
greghughespdx's Avatar
Note that Van's has also published a Service Bulletin for these sensors.
https://www.vansaircraft.com/service...ions/sb-00006/
Greg Hughes - Van's Aircraft
Building RV-8A since Sept 2014
Aurora, OR (EAA Chapter 105)
Old 05-06-2020, 05:23 PM
Pilot135pd's Avatar
Pilot135pd Pilot135pd is offline
I read your SB and it says it applies to all aircraft then it says to read the Dynon SB. Dynon says it's since 2012. My RV-8 was completed in 2009 and I checked the Optional Parts Drawings you mention in your SB and don't see any pressure sensor model numbers. Does it not apply to older RVs?
UPDATE : Disregard, mine has German VDO sensors.
Sadly sold my RV-8 however still trying to enjoy life by living on my airport with FREE campsites for pilots to enjoy www.facebook.com/VacaMooAirport/ & flying my OnSpeed equipped C-177 while waiting for the RV15 !
Exempt by 3 out of the 10 ways but I still donated.
Old 05-06-2020, 05:27 PM
Jpm757's Avatar
Jpm757 Jpm757 is offline
Does anyone have a source for the new Kavlico sensors? I have 2 of the affected sensors installed and would like to replace them when available.
Jake
RV6 #20477 completed 1991 sold.
RV7 #72018 N767T first flight 11/21/2017
(KOXC)Oxford, CT, (0NY0)North Creek, NY.
1941 J3 Cub skis, floats.
Building Javron Super Cub.
2020 dues gladly paid.
Old 05-06-2020, 05:37 PM
Pilot135pd's Avatar
The SBs have that info.
Old 05-06-2020, 05:43 PM
We have never directly provided or specified a specific sensor for the RV-8 (or many of the other RV models other than the RV-12/12iS and in the past the RV-14). You are directed to refer to the document for your specific manufacturer, determine whether or not you have an affected sensor using the manufacturer's document, and from there take the appropriate action. We have no way to know whether or not you have an affected sensor(s), since it would have been acquired when you purchased your avionics parts from another vendor, hence the direction to review and examine the sensors installed in your aircraft, then take appropriate action.
Our SB is intended to make you aware of the need to review applicability and act, especially given the potential risk involved should a combustible fluid sensor fail.
Hope that helps.
Old 05-06-2020, 06:52 PM
Champ's Avatar
Champ Champ is offline
Anyone experienced similar problems with VDO pressure transducers? VDO transducers came with my sensor kit from Dynon in 2006. The kit PN is EMSKIT-L4F (for fuel injected engines). I'm sending Dynon an email questioning this as well.
Dennis Enns
Bellanca Champ 7ACA since 1986, restored 1990.
RV-8 IO375, MTV-9-B/183-50a, PMags, OW Award Oshkosh 2017
2021 Donation In
Old 05-06-2020, 07:26 PM
DFlyer DFlyer is offline
We know of no similar leakage issues with the VDO sensors that we sold prior to 2012.
-Robert
Dynon Avionics
Old 05-06-2020, 07:30 PM
GalinHdz's Avatar
GalinHdz GalinHdz is offline
FWIW: This has nothing to do with the EFIS or even when it was built/installed. It has everything to do with the sensor(s) installed in your airplane. You need to check your sensor, even if you don't have one of these particular EFIS.
Galin
CP-ASEL-AMEL-IR
FCC Radiotelephone (PG) with Radar Endorsement
2021 Donation made
www.PuertoRicoFlyer.com
