Old 05-29-2007, 07:55 AM
briand's Avatar
briand briand is offline
Default Digiflight II Servo's
Whats the dif. between Trutraks standard and VS servos?
Old 05-29-2007, 08:14 AM
mlw450802's Avatar
mlw450802 mlw450802 is offline
I may be out to lunch here and if so, I am sure it will be corrected but I believe the servos are the same. The vs version autopilots have 'vertical steering' capabilities.
Mike
Michael L Wilson
Resuming building after a 4ish year hiatus! (life got in the way)
N194MW (reserved) RV9A SB
VAF# 148
Payson, AZ
Old 05-29-2007, 08:18 AM
PJSeipel PJSeipel is offline
There is a difference between the trim sensing and non-trim sensing servos though (i.e. if you get the automatic pitch trim).
PJ Seipel
RV-10 #40032
Old 05-29-2007, 10:21 AM
briand's Avatar
PJ Seipel
RV-10 #40032
That must be it, thanks.
Old 05-29-2007, 05:39 PM
SteinAir SteinAir is offline
That is correct. The "VS" servos are used on the Digiflight II "VS" series and up autopilots (and also includes the Altrak VS). Otherwise they are the basic servos that don't sense trim...
Stein.
Old 05-29-2007, 06:30 PM
mannanj's Avatar
mannanj mannanj is offline
Default TT VS Servo Difference
$250.00 if I remember right
LAUS DEO
Mannan J.Thomason, MSGT. USAF (RET)
VAF788
"Bucket List" checkoff in progress!
