Old 04-11-2020, 09:06 PM
Simon Hitchen's Avatar
Simon Hitchen Simon Hitchen is offline
Default Extended go pro mount
If you’re looking for a little quarantine project....
I Wanted a better perspective for inflight photos so I made this mount to extend ahead of the wing by 2 feet. Makes a real difference.
I used 3/4” carbon fibre tubing with 3/4” aluminium square stock (all provided by my hangar mate John). I fabricated the brackets to fit into existing holes/nut plates for the wing tip attach points.
I was worried about vibration but it turned out great.
First photo is of the mount without the camera on the end. Second is a photo with the go pro mounted on top of the wing (old position). The third photo is with the camera mounted on the new carbon fibre extension rod. Much better photo.
Simon Hitchen
Port Perry, ON, Canada
7 Tip Up, Titan XIO-360, Dual P-Mags, Airflow Performance matched Injectors, Sensenich FP Prop, 2 Dynon Skyviews, GPS-175, GTR-200, GTX-327. Day/night VFR/ IFR
Old 04-11-2020, 10:52 PM
PixelWorker PixelWorker is offline
Very nice! That is a much better angle.
Michael Jensen
RV7A - Aero Country T31
Old 04-12-2020, 05:46 AM
plehrke's Avatar
plehrke plehrke is offline
Originally Posted by Simon Hitchen View Post
I used 3/4? carbon fibre tubing with 3/4? aluminium square stock (all provided by my hangar mate John). I fabricated the brackets to fit into existing holes/nut plates for the wing tip attach points.
I have been thinking of doing something similar. What is the wall thickness of the 3/4? carbon tubing?
Philip
RV-6A - flying 970+ hours
Based at 1H0 (Creve Coeur)
Paid dues yearly since 2007
Old 04-12-2020, 05:56 AM
Default Thickness
I?d say probably 1/8th inch wall thickness
Simon Hitchen
Old 04-12-2020, 07:28 AM
Don Patrick's Avatar
Don Patrick Don Patrick is offline
Default Beauty!
Great video,
By the time I got up there, it was overcast!
DP
Old 04-12-2020, 08:38 AM
BobbyLucas's Avatar
BobbyLucas BobbyLucas is offline
If I ever get this point, I want to duplicate Trent Palmer's "impossible camera angle." Looks like you've got a chase plane with telephoto lens. Magic!
https://www.youtube.com/watch?v=_Fq33dHNSfI
Bobby Steinmetz
Van Buren TWP, MI
Student Pilot, Mechanical Engineer, Donating Member
RV-12iS #121228
  • My opinions are JUST my opinions, not facts
  • Regardless of phrasing or colorfulness, my opinion does not imply that any opposing opinions are wrong or ANY less valid than my own
  • Respect people by giving your own opinion without attacking or belittling others
  • Passive-aggressive is not better than overt-aggressive
  • When I fail to meet these standards, please call me out, gently
Old 04-12-2020, 09:36 AM
zmatt zmatt is offline
Yea, the shots that he gets with his setup are amazing. Looks like he has his mounted forward of his prop slightly.
Old 04-12-2020, 09:53 AM
kaweeka kaweeka is offline
I love it!! I've been wanting to do the same from the VS, mounting my 360 Fly to get shots "above" the aircraft. I'm not a machinist, nor do I have access to create the exquisite mounting hardware you have. Kudos! Can you or your hangar mate duplicate the mounting hardware?
David
RV-9A N435KR, Vans calendar March 2018
LIO 320 B1A, Dual LS Plasma III, AFP injection
G3x touch
Roseville, Ca
Old 04-12-2020, 10:15 AM
Default video
HI David, yes it can be duplicated but I made the pieces to match the holes I had already drilled to attach the wing tip. Not even the same as my other wing...
Here's a video in flight before landing, really pleased with the results. Id like to pick up a 360 though.
In case anyone's wondering i was always above 500 feet and more than that away from the shore!
https://youtu.be/nzjKXAWEp0I
Happy Easter everyone
Simon Hitchen
Old 04-12-2020, 10:48 AM
Would these mounts be something that would lend itself to 3D printing?
G3x touch
Roseville, Ca
