Old 04-09-2020, 04:25 PM
Glen P Glen P is offline
Default Fibreglass around counterweight
I'm new at this fibreglass business. I closed up the HS and VS tips with foam, flox and micro balloons. I applied some flox and then some micro balloons to the counterweight to see how well it would adhere. I adhered well. Now I'm wondering whether I could add some more micro to give it more of a finished look (after riveting on the tip). Any problems with this plan?
Glen Palmer
Toronto, Ontario
Working on -7 avionics/wiring
Dues paid July 2021
Old 04-09-2020, 05:17 PM
DanH's Avatar
DanH DanH is offline
There are several ways to skin that cat. Here is one which won't sprout future cracks..
Dan Horton
RV-8 SS
Barrett IO-390
Old 04-09-2020, 06:35 PM
Thanks, Dan. How many plies would you say?
Glen Palmer
Toronto, Ontario
Dues paid July 2021
Old 04-10-2020, 07:26 AM
DanH's Avatar
Well, as a rough rule of thumb, fabrics in the common 9 oz range tend to be about 0.010" per ply. No structural load here, so no need for concern. Just match the thickness of the existing glass.
Dan Horton
RV-8 SS
Barrett IO-390
Old 04-10-2020, 09:49 AM
goatflieg's Avatar
goatflieg goatflieg is offline
I followed the procedure you're planning, but I used flox instead of microballoons. Encapsulated the end with the seams packed with flox; applied peel ply. After curing, I carved the ends into shape, touching up as required, then filled, primed and painted. Time will tell if it will endure the rigors of flight; examining those counterweight tips will be an essential part of every preflight for me.
Martin J Filiatrault
Clarkston, MI
RV-8 #83507 - registered; final assembly continues; engine remounted.
Builder websites:
http://goatflieg.blogspot.com/
http://www.mykitlog.com/goatflieg/
YouTube Channel:
https://www.youtube.com/user/goatflieg
Dues paid for 2022... extra payment included for psychological therapeutic services rendered.
_______________________
Have you ever gotten the feeling you were smarter than you could ever prove?
Old 04-10-2020, 03:35 PM
wirejock's Avatar
wirejock wirejock is offline
Default Elevator tips
I'm working on this now. I'm curious.
Nevermind. It was a dumb question
Larry Larson
Estes Park, CO
wirejock at yahoo dot com
Donated 01/01/2021, plus a little extra.
Empennage, wings, fuse, finishing kit, now FWF
Disclaimer
