Old 03-17-2020, 03:31 PM
MCA's Avatar
MCA MCA is offline
Default Feedback for "Aircraft Wiring Guide" Book
I'm looking for feedback from those that have read the Aircraft Wiring Guide (see link in the signature below) and wanted to get any input about:
- new topics to include
- updates to existing topics
- fixes
- useful comments in general to improve the book
Please comment below or send me a PM.
Thanks!
Marc
Marc Ausman
RV-7 980 hours, IO-390, VP-X (sold)
RV-8 (flying a friend's)
Thinking about low and slow backcountry build.
Fly Navy!
VAF Advertiser - Aircraft Wiring Guide
Book to help with experimental aircraft wiring.
Old 03-18-2020, 07:49 PM
Steve Crewdog's Avatar
Steve Crewdog Steve Crewdog is offline
Just ordered one. Looks good, since I'm in the middle of redoing my wiring.
Suggestions:
What a shunt is and why you do/don't need one in your system.
Service loops: leaving wire so you can remove stuff for repair later.
Allow the option to have both a print and electronic version for one price. I'd love to keep the print version at the hangar so I can write notes on it, etc., but don't want to take it along on a trip, I'd lose the dang thing, and on a crowded airplane it's easier to read an e-book.
SeaRey builder lurking to get ideas to make his plane better.
Dues paid for 2021
http://seareybuild.blogspot.com/
Old 03-18-2020, 09:01 PM
BlndRvtr BlndRvtr is offline
Digital version for my iPad.
I'm re-reading now, will make content suggestions when I finish.
George
Old 03-19-2020, 07:42 AM
DanH's Avatar
DanH DanH is offline
Marc, perhaps much expanded sections on alternators, regulator types, and over-voltage protection methods. Lithium-iron batteries too.
Dan Horton
RV-8 SS
Barrett IO-390
Old 03-20-2020, 12:37 AM
A1AVIATON47 A1AVIATON47 is offline
Default book
one on the way
Old 03-20-2020, 08:05 AM
Marc,
I really appreciated you and your book when I was wiring up my plane. I agree with Dan that alternators, voltage regulators, and the new batteries. For alternators I would like more info on the substitute auto or tractor units and how they match up with the airplane units. That may not be what your book is geared for so thats fine.
Good luck with the new book. I will buy one even though I am finished with my wiring!
rockwoodrv9a
Williamston MI
O-320 D2A
Flying N376E
Old 03-20-2020, 09:30 AM
N941WR's Avatar
N941WR N941WR is offline
I have not had the pleasure of reading your book, so I can't comment directly on it.
However, watching the forums, it is obvious that many homebuilders go crazy with the backup systems and that should be addressed.
In my case, my SkyView has a battery backup, my PocketPanel has an internal battery to backup the SkyView, and I have kept a handheld GPS in the panel to back that up. Not to mention P-mags (standard magnetos will do the same) so no need for a backup power source for those, or the electronics.
In my situation, I wouldn't care if the transponder and ADS-B went dark but would like a battery to keep one radio alive.
I fear that people make their electrical systems so complex that they introduce failure modes when they need the system to function properly the most. Having multiple switches to flip isn't a good solution as people get stressed and talk themselves out of going to their backup system.
Good luck with your changes!
Bill R.
O-360 w/ dual P-mags
SC86 - Easley, SC
www.repucci.com/bill/baf.html
Old 03-20-2020, 09:32 AM
AlpineYoda AlpineYoda is offline
I have a copy on the desk next to me! It is a great reference for the basics of things like busses and the layout of fundamental components.
If you wanted to significantly expand it, you could include discussion of the wiring of various avionics, lights, antennas, etc. I realize that each system is different and it may be hard to make general comments, but some examples of the actual hardware and how to wire it could be interesting.
RV-10 build blog -- https://eaabuilderslog.org/?blproject&proj=7ZSwfzr2g
Started 12/19/2019
Engine hung 1/9/2021
Panel hopefully coming fall 2021
N1814T reserved with FAA
Donated Jan 11 for 2021, EAA and AOPA member
Old 03-20-2020, 09:45 AM
riseric's Avatar
riseric riseric is offline
Default Integration of different systems
Hi Marc,
Suggestions on how to integrate different electrical options or systems.
For example, although most venders provide detailled instructions to install their products, there are few if any suggestions or "watch-out" when more than one system is installed. One realises that they cannot predict what a builder installs or not...
I did a lot of head scatching and asked questions when planning/installing an electronic circuit protection (such as VPX) system and Flyefii's Bus Manager so that neither system would interact negatively between each other.
Eric,
2021 dues happily donated
RV-8 slow built #83274
Grove Airfoiled Gear, Wheels & Brakes
VPX-Pro, EFII System 32, EarthX batteries
Aerosport IO-375, MTV-9-B/183
Skyview HDX
C-GEMQ, RV-8, flying
C-GNFJ, C72R Cutlass, flying
Old 03-20-2020, 02:02 PM
JoopSJ's Avatar
JoopSJ JoopSJ is offline
I have the AWG and also the AeroElectric book.
AeroElectric is a bit to amplified for me and AWG is too superficial.
So I would appreciate something in between.
And I agree with DanH's list.
Empennage, Wings, Fuse .. Done
Working on Finishing and FWF
Donation 2017. . . 2020
Chairman NVAV (EAA chapter 664 - Dutch experimental aircrafts builders)
Member EAA
Member AOPA
