Old 03-10-2020, 04:40 AM
Clouddancer Clouddancer is offline
Default Brake Flange ? Hole Pattern
I am looking for the dimensions of the standard hole pattern for the Cleveland brake flange on an RV-4. I was not able to find it on the Vans drawings, nor in a Cleveland documentation. Does anybody know the exact dimensions or where to find it?
BrakeFlange by Clouddancer, on Flickr
Andreas Uebersax
RV-4 SN2416 in slow progress
Switzerland
VAF donation 2020/11/26
Old 03-10-2020, 08:02 AM
HFS HFS is offline
Default Dimensions
The Grove catalog shows:
A) 1.370"
B) 1.370"
D) 1.938"
HFS
Updated information: The above information was taken from Van's Dwg. 38 from 1985 for S/N 1136. P/N U-403 "Brake Mt. Flange" shows four (4) equally spaced holes (90* offset) x 1/4" diameter.
Information taken from Van's Dwg. 38 from 1993 for S/N 3392, Revision 7 (1/92) for P/N U-403 "Brake Mt. Flange" shows 4 x 1/4" holes, on a 1 15/16" diameter circle, with the narrow hole pattern at a 29* offset from the Center Line (or 58* degrees from each other). Yielding dimensions of: .938 between narrow holes, and 1.688 between wide holes, on a 1 15/16" diameter circle.
Old 03-10-2020, 09:50 AM
Thanks. But what I see on the Cleveland and Vans flange is more something like a=15/16. I think the Diameter D could be 1 15/16.
Andreas Uebersax
Switzerland
Old 03-10-2020, 10:24 PM
Scott Hersha Scott Hersha is offline
1-15/16 is 1.9375...... pretty close to 1.938. Sounds the same to me.
SH
RV6/2001 built/sold 2005
RV8 Fastback/2008 built/sold 2015
RV4/bought 2016/sold/2017
RV8/2018 built/Sold(sadly)
RV4/bought 2019 Flying
RV6/Used kit purchased 2021 building
Cincinnati, OH/KHAO
JAN2021
Old 03-11-2020, 05:56 AM
Yes, I am pretty confident with the Diameter D being 1.938" resp. 1 15/16".
But the Cleveland brake flanges that I have, a is not even to b. And I am a bit surprised I cannot find those dimensions although those seem to be some kind of "standard".
Andreas Uebersax
Switzerland
Old 03-11-2020, 10:56 AM
akabud akabud is offline
That is the same as a 1 15/16 bolt circle with 6 evenly spaced holes, 60° apart.
But it's missing two holes.
So A is .96875 (31/32) and B is 1.67792 (1 43/64).
The dimensions from Grove is for four holes 90° apart.
RV-6 Built and sold
Rv-3A Bought. Flying.
Old 03-12-2020, 07:58 AM
HFS HFS is offline
Default Brake Flange Dimensions
Check your PM's
HFS
