Hi All ?
There?s a new optional kit available to order form the Van's web store as of last night. We have several in stock now. It's called "ACCESS PANEL KIT" and is designed for use on the RV-7/9/10/14. It can be used during new construction, or as a retrofit installation (in which case you'll drill out two applicable rivets so you can fit the template).
The kit sells for $19.00, so let's face it, it?s a freakin? bargain. Try that, certified world!
https://shop.vansaircraft.com/cgi-bin/shop.cgi?browse=new&product=AccessPanelsKit
This particular kit was initially the work of our friend Joe Blank, who worked in technical support here at Van's and unfortunately passed away a few years ago. We were able to pick up his work and finish it off so we can share it with you.
This kit was created in response to customer desires/requests over the years. Our engineering team has worked recently to select and deliver a handful of these smaller enhancement requests when they can find a few cycles (and that doesn't happen often - did I mention we are hiring engineers?) with the goal of delivering options that people can choose from if they wish. Other recent examples include this kit, the cowl louvers kit, the AHARS mounting bracket kit, RV-12 step plugs and optional style throttle handle, etc. You'll find those on our web store in the "New Products" section.
What this kit does: Allows the builder to put a couple of access panels in the skin ahead of the windscreen, which can be removed in the event there's a need to get into the area between the firewall and the subpanel located at the back of the avionics bay. Some builders want this so they can get access without having to contort themselves upside down under the instrument panel while doing maintenance. You do need to use a sealant when installing the panels, so the primary tradeoffs here are easier access vs. the potential for leaks if not properly sealed when closed up.
The instructions page (OP-43) is linked from the kit?s web store page, and that document should answer any questions you have about how one applies this kit and how the parts fit, etc. There are template instructions for each of the airplanes it applies to, all explained in the OP-43 document.
Again, this kit is designed for and includes templates for the RV-7/7A, RV-9/9A, RV-10, and RV-14/14A.
