Old 02-09-2020, 08:56 PM
Steve Melton's Avatar
Steve Melton Steve Melton is online now
Default fuel line - severe abrasion
a second owner aircraft. previous A&P inspection. flying for a couple of years. owner inspection found severe fuel injected fuel line wear abrasion. in true honesty, perhaps the best inspector is the guy behind the stick. not much time left for this hose.
Steve Melton
Cincinnati, OH
RV-9A, Tip-up, Superior O-320, roller lifters, 160HP, WW 200RV, dual impulse slick mags, oil pressure = 65 psi, EGT = 1300F, flight hours = 900+ for all
I was born an airplane nut. I have no explanation for it.
www.rvplasticparts.com
Old 02-09-2020, 09:26 PM
AlexPeterson's Avatar
Wow, good catch. What was chowing on it? Should one perhaps replace the fitting this was attached to also?
Alex Peterson
RV6A N66AP 1750+ hours
KADC, Wadena, MN
Old 02-10-2020, 08:31 AM
RV7 To Go's Avatar
RV7 To Go RV7 To Go is offline
OMG...that looks like it was ground out by by a Dremel/die grinder for clearance. What did the other part look like? That just goes to show you can never have too many eyes checking out your plane!
Al
___________
RV4 - Bought 2013 Sold 2017 after 450 hrs
RV7 - Built in 6.5 yrs & Flying 2017
RV4 - Built 2021 Time flown and Sold
Old 02-10-2020, 03:09 PM
And the plated brass crimp collar and JIC nut. Definately not a good thing, and was overlooked apparently several times.
Tom
RV7A Tail Kit Completed, Fuse started-Pay as I go Plan, on hold while we develop new products for RV builders
Ridgeland, SC
Old 02-10-2020, 03:28 PM
Tom
the expert is in the house.
Steve Melton
Cincinnati, OH
Old 02-10-2020, 03:31 PM
Bob Martin's Avatar
Bob Martin Bob Martin is offline
Steve,
You said fuel ingection line...
I am guessing it was close the spider....and maybe rubbing on the engine split line? Only area where I can think a line would be close enough to rub.
Give us a hint so we can check our planes.
Bob Martin
RV-6, 0-360 Hartzell C/S, Tip up, 1200+TT
James extended cowl/plenum, induction, -8VS and Rudder. TSFlightline hoses. Oregon Aero leather seats.
D100-KMD150-660-TT ADI2- AS air/oil seperator. Vetterman exhaust with turndown tips.
Louisa, Virginia KLKU N94TB
Old 02-10-2020, 03:35 PM
correction, fuel pressure line to the transducer on a fuel injected engine. pilot side down low.
Steve Melton
Cincinnati, OH
Old 02-10-2020, 05:19 PM
That looks pretty close to a very bad flight. A good reminder to inspect all the fuel hoses very carefully at least yearly.
rockwoodrv9a
Williamston MI
O-320 D2A
Flying N376E
Old 02-10-2020, 05:22 PM
directly above the exhaust pipe. this guy must be living right.
Steve Melton
Cincinnati, OH
Old 02-10-2020, 10:26 PM
dreed dreed is offline
Oof... good catch- scary stuff.
This brings back memories. My former 1961 172 had someone route the R/H rudder cables under the fuel line upstream of the fuel selector (where the R/H wing feeds the selector)- sawed through the AL tubing so much that it was paper thin. So thin that if you looked down the ID of the tube, it was no longer round and had a very pronounced protrusion inward.
We cut it out, re-flared it and fixed the cable routing but like the posted the fuel would have been in the bulkhead right behind the exhaust with no way to shut it off.
I found this on my own during an assisted annual, but it had several previously at the same shop unassisted. Like RV-7 to go said, the more eyes the better.
Dan Reed
Camas, WA
RV-7A - N167DR
First flight 5/25/2021
Phase 1
2018/19/20 VAF dues paid
