Old 02-03-2020, 07:06 AM
JackinMichigan's Avatar
JackinMichigan JackinMichigan is offline
Default Big ole dent in prop leading edge
I'm hoping the picture came thru.
I noticed this little surprise during my condition inspection. It must have just happened because I didn't notice it during my last preflight, and I make it a point to check the prop leading edges.
This is an MT constant speed 3-blade composite prop with all of 53 hours on it. The edges don't feel sharp and it didn't break thru the protective aluminum leading edge, so what should I do about this? Do I do anything?
Jack and Dave Groat, father and son
RV-10 N1861G
Build #41389, started Oct 2012
Current status: 1st Flight 11/10/17
50 hour oil change: 8/29/19
Old 02-03-2020, 07:29 AM
steve murray's Avatar
steve murray steve murray is offline
Not able to see the picture.
Steve
RV10 - Flying (Jan 2020)
RV8 - Built 2006- Flown 800 hours Sold 2021
RV4 Kit Purchased 2021
Old 02-03-2020, 07:49 AM
Dan 57's Avatar
Dan 57 Dan 57 is offline
no pic either...
But you might want to check MTs Service Letter for in field repair https://www.mt-propeller.com/pdf/sls/sl32r5.pdf
Damaged one blade on my 3-bladed a while ago... sent some pictures and measurements to MT-Propeller support. Was happily surprised when a few hours later I received specific repair instructions and the SL above, all resulting in a quick repair
Life's short... Enjoy!
http://www.aerofun.ch
RV-6.9 #25685, slider, O-360-A3A (carb/dual Lightspeed II), MTV-12-B, HB-YLL owner & lover
RV-4 #2062 HB-YVZ airframe builder
Old 02-03-2020, 08:41 AM
mike newall's Avatar
mike newall mike newall is offline
Check the MT site, if no exposure of the substrate, or no cracks in the leading edge, scuff up, degrease, fill with epoxy or JB Weld and smooth out with wet and dry.
Ours has several little dinks in, no problem.
"I add a little excitement, a little spice to your lives, and all you do is complain!" - Q
Donated in 2021
Old 02-03-2020, 08:42 AM
9GT's Avatar
9GT 9GT is offline
The 3 blade MT composite on my buddies Cozy MKIV we built gets chewed up more often than expected due to it being a pusher. The first time, we sent some pics to MT and they also recommended a simple DIY fill and file procedure for the repair. We did that several times over the years until delamination started and it was time to remove and drop the prop off at Tiffin Aire for a complete strip, re-wrap, overhaul, and paint. I think that ran around $4K for everything. Looked like new when picked back up.
David C.
Howell, MI
"Donor Exempt" but donated through Dec. 2021
Old 02-04-2020, 09:49 AM
The leading edge is either stainless steel or nickel depending on type. Provided there are no cracks in it, it can be dressed and filled.
Plenty of info on the various MT resource sites.
Donated in 2021
