Originally Posted by Pilot135pd
I was going to make a dipole with coax but I've got some aluminum strips I can cut too. Thanks.
A dipole won?t fit, won?t work well in the tip, will be oriented incorrectly.
To copy the Archer, make sure you copy the built-in capacitor exactly (area, spacing, and dielectric material). It?s better if you can borrow some ham radio equipment, like an antenna tuner.
I?ve never had an issue with an ils signal, localizer or GS. I have tuned in a distant vor (over 40 nm) and done a 360, and seen it flag when the vor was at 90 deg to the airplane axis, so the signal had to go thru the fuselage. Closer (stronger) signals, no problems noted.
I?ll also say that I?ve seen photos of Archer installations that were unbelievably bad (2 cases). It?s amazing they worked at all. So sometimes negative comments are due to installation errors.
