Old 01-24-2020, 08:01 PM
Jpm757's Avatar
Jpm757 Jpm757 is offline
Default Blocked Pitot
Took off today with my Pitot cover installed. I am running dual Dynon ADAHARS and dual AFS 5600t's. Other than no airspeed or AOA, everything else functioned normally. I had always been curious how a blocked Pitot would effect the system as a whole. Stopped at a local airport and replaced my now ragged cover with a new one with a big red banner. Lesson learned!
Jake
RV6 #20477 completed 1991 sold.
RV7 #72018 N767T first flight 11/21/2017
(KOXC)Oxford, CT, (0NY0)North Creek, NY.
1941 J3 Cub skis, floats.
Building Javron Super Cub.
2020 dues gladly paid.
Old 01-24-2020, 08:10 PM
GalinHdz's Avatar
GalinHdz GalinHdz is offline
So it did not give you an warning that it was using GPS for speed instead of airspeed?
Galin
CP-ASEL-AMEL-IR
FCC Radiotelephone (PG) with Radar Endorsement
2021 Donation made
www.PuertoRicoFlyer.com
Old 01-24-2020, 08:38 PM
Jpm757's Avatar
Only indications were airspeed "0" and AOA off scale low.
Jake
Old 01-27-2020, 01:31 PM
jwilbur jwilbur is offline
Default same
I did the same dumb thing recently. I have Dynon HDX and a backup Dynon D6. I realized just as I was lifting off and decided to continue once around the pattern. I got GPS assist indications on the HDX and the D6. The only other thing of note was the Dynon giving me a warning to turn on pitot heat (I guess it assumes it is iced over). .... Classic distraction during preflight inspection kind-of-thing. A non-event, but I don't plan to repeat the "experiment".
-Joe Wilbur
Old 01-28-2020, 10:33 AM
Amit's Avatar
Amit Amit is offline
I recommend everyone take off once with the airspeed indicator covered, and go around the circuit and land.
It is a very good exercise in my mind (do it with a safety pilot if you want to be extra safe, and remember you can remove the cover if you are so inclined).
Then, in the unlikely future event of no airspeed indication, you would have the knowledge that you can land the airplane regardless.
I did this twice and found it an invaluable experience.
Old 01-28-2020, 10:58 AM
airguy's Avatar
airguy airguy is offline
I'll admit to being in that club as well, though not because of a pitot tube cover.
I was removing my MGL mini-EFIS and replacing it with a Garmin G5, and was right in the middle of all the work when a perfect afternoon for a quick flight presented itself. I hit the power on the runway and was at rotation speed before I realized I didn't have any airspeed indication - and immediately realized why, when I glanced at the round hole in my panel where the G5 would eventually live - and the open pitot and static lines in the middle of that hole, happily venting to cabin pressure.
Knowing your airplane, the way it feels and sounds at various airspeeds, sure is a nice handy skill to have. Once around the patch and back down we go...
Garden City, TX VAF 2021 dues paid
N16GN flying 900 hrs and counting; IO360, SDS, WWRV200, Dynon HDX, IFD440, G5
Old 01-28-2020, 12:17 PM
9GT's Avatar
9GT 9GT is offline
It happens to the best of pilots. Last fall my hanger neighbor, who has flown for over 40 years and is also an AP/AI, asked me to go up with him in his Bonanza so he could check out the new GTN 750 he just installed. He also realized what he had forgotten to do at right about rotation speed. He was pretty embarrassed about that. This is a prime example of why I ALWAYS do a thorough pre-flight with my pre-flight check list in hand. That's not a guarantee you won't miss something,,,,,but it helps.
David C.
Howell, MI
"Donor Exempt" but donated through Dec. 2021
Old 01-28-2020, 01:12 PM
Dan 57's Avatar
Dan 57 Dan 57 is offline
Whoaa Greg, you’re The Best
Ok, also managed a take-off with Vans pitot cover still on... funnily enough I had airspeed numbers, though all delayed. Flew 1/2 hour at reduced speed, landed, and the cover was still there, no damage, no unstitched seams, go figure...
Life's short... Enjoy!
http://www.aerofun.ch
RV-6.9 #25685, slider, O-360-A3A (carb/dual Lightspeed II), MTV-12-B, HB-YLL owner & lover
RV-4 #2062 HB-YVZ airframe builder
