Old 01-05-2020, 07:58 PM
newt's Avatar
newt newt is offline
Default RV-6 engine replacement
My RV-6 is on about 1830 hours. I'll have an annual condition inspection in October, then I think there'll be engine work in 2021.
Current engine is a carburetted O-320-D2A with a Sensenich fixed-pitch cruise prop.
I didn't build the aircraft.
The current fuel system has plumbing feeding an Andair valve supplying the suction side of a Facet fuel pump on the inside wall of the fuselage between the pilot seat and the rudder pedals, with the pump discharge feeding a gascolator on the engine side of the firewall, which in turn runs to the engine-driven fuel pump.
It's still more than a year and a half away, but planning is good, and the direction I'm tending towards now is to take the O-320-D2A off and replace it with some variant of an IO-360, probably also with a fixed-pitch prop.
The change from carburettor to fuel injection is going to involve fuel system modifications: I'm anticipating that the Facet pump will end up in the trash, with a new high pressure fuel pump and new plumbing.
I'm sure someone has gone down the path of carb to fuel injection before, and if anyone has advice I'd love to hear about it.
Are folks generally keeping high-pressure fuel out of the cockpit, so where's the right spot for the electric pump? Is the gascolator necessary? Considerations for routing fuel lines to avoid vapor lock? How are fuel systems handled in modern certified aircraft? Anything else I'm not thinking of?
- mark
[ Paid up on 16 Jul 2021 ]
RV-6 VH-SOL
Old 01-05-2020, 08:21 PM
Sam Buchanan's Avatar
been here awhile
If it has good compression, doesn't use oil, and isn't making metal......fly it!
....unless you just want a new engine......
Sam Buchanan
RV-6
Old 01-05-2020, 09:03 PM
N941WR's Avatar
N941WR N941WR is offline
That is the "standard" fuel system for a carburetor, with the exception of the Andair valve, the builder opted to replace the standard valve with the Andair same location, same function.
- mark
The "standard" FI setup is to put the high pressure backup pump just forward of the Andair fuel valve.
The gascolator comes out and can be replaced with a bulkhead fitting to fill the hole.
Somewhere in that mess, you might want to think about installing a fuel flow meter (the type depends on your engine monitoring system).
Contact Van's and ask them for the drawings for the fuel injected setup, they are pretty generic.
What I don't know is if you will need a shorter engine mount when you switch to the IO-360 parallel valve engine from your O-320.
Good luck!
Bill R.
O-360 w/ dual P-mags
SC86 - Easley, SC
www.repucci.com/bill/baf.html
Old 01-05-2020, 09:29 PM
newt's Avatar
That's certainly a consideration. But it butts up against the extremely annoying way that I get left behind on the outside of echelon turns with RV-7s An IO-360 is less than 7 kg heavier than an O-320. Hardly any weight for quite a bit of extra power margin.
Besides: It's 2020, and we worked out how to eliminate carb ice risk half a century ago. It's borderline embarrassing to still have to deal with it.
- mark
RV-6 VH-SOL
Old 01-05-2020, 09:30 PM
newt's Avatar
That is a fascinating consideration, and I'm glad I asked here.
Thank you!
- mark
RV-6 VH-SOL
Old 01-06-2020, 02:00 AM
az_gila's Avatar
az_gila az_gila is offline
Wink
Thank you!
- mark
I switched from an O-320 to an O-360 during my build on a RV-6A and used the same motor mount.
Gil Alexander
RV-6A N61GX - finally flying
Grumman Tiger N12GA - flying
Old 01-06-2020, 05:03 AM
Dan 57's Avatar
Dan 57 Dan 57 is offline
re carb icing, never had any icing with my O-360 despite extensive use in conditions prone to produce. But never say never...
On the other hand the main advantage of switching to a fuel injection would be fuel economy since a more effective LOP can be done. Inlet icing is still very possible and probable in given conditions, so an alternate air is a must.
Life's short... Enjoy!
http://www.aerofun.ch
RV-6.9 #25685, slider, O-360-A3A (carb/dual Lightspeed II), MTV-12-B, HB-YLL owner & lover
RV-4 #2062 HB-YVZ airframe builder
Old 01-06-2020, 07:36 AM
been here awhile
- mark
Just as a datapoint.....I've been flying my RV-6 (O-320, carb) since 1999 and have had two minor carb ice incidents, both during mile-long taxi with a cold engine after the first start of the day. Even though we see very humid conditions in Alabama I have never experienced in-flight carb ice with the O-320.
Now the O-200 in the biplane is another matter...that thing can make ice in a heartbeat!
Sam Buchanan
RV-6
Old 01-06-2020, 07:39 AM
Mark33's Avatar
Mark33 Mark33 is offline
Gil, can you tell me ?approximately? how much further the 320 mount pushes the engine out as compared to the 360 mount? I?m thinking about using the 320 mount on my Catto prop equipped PV 360 -7 build to help with W&B.
Mark H.
RV-7- IO-360, EFII, Whirl Wind C/S, (Built and sold)
RV-4- O-320, Catto three blade, P-Mags (Sold)
RV-8- IO-360, Hartzell C/S (Flying)
RV-7- (Building)
Old 01-06-2020, 08:38 AM
Northernliving Northernliving is offline
I’m in the middle of converting from an O-360 to a newly built IO-360 in an RV 8. This is the pump that I plan on using.
https://airflowperformance.com/index...pump-assembly/
Brian J.
Boston, MA
RV8 Based at ORH - Purchased
RV8 - The Project #83313 - Under Construction
