Old 12-14-2019, 04:26 PM
Tacco Tacco is offline
Default Annual Findings and a Question
Annual - wow, that took a while!
Found I had not primed inside counterbalance arm but no corrosion visible. Left it for now. Anyone else forget to do this?
AoA failed leak check. Tracked down the fitting at the ADHRS box. Just reset it, passed fine.
Do yourself a favor, replace the Phillips head screws on all the cockpit panels with Torx....soooomuch nicer to deal with.
Steve Morrow
RV-12 N12SM
Builder 121036
White Salmon, WA
2020 Donation Paid
Old 12-14-2019, 10:23 PM
rongawer rongawer is offline
If you're concerned about corrosion, you could spray out the tail with Corrosion X. It takes a few minutes and lasts a couple years.
I did use cap screws on my panel, but kept Phillips for all of the floor pans to keep a smoother surface.
Ron Gawer
- RV10, N762G, Build in progress.
- Several others that are now just great memories for me.
Old 12-15-2019, 09:27 AM
funflying funflying is offline
I found some corrosion in one of the flaperon tubes once the wings were removed. I cleaned it as best I could like the barrel of a shotgun and then applied Corrosion X like the previous post.
I will check my counter balance tube this annual. Thanks for the tip.
Patrick Claar
Arvada, CO BJC
RV12, #401, Flying 2013, N612PC
RV6, 1996-2010 sold
Old 12-19-2019, 10:49 AM
pjc's Avatar
pjc pjc is offline
Default +1 for Torx
Just changed out Philip?s pan head for Torx at this year?s CI. Much easier and cleaner going back together. No more stripped heads. Highly recommended upgrade (but one more tool required in my travel kit).
Peter
Vans RV6 flying
SZD 48-2 sold
2018, 19, 20 Dues paid
Old 12-19-2019, 11:56 AM
N941WR's Avatar
N941WR N941WR is offline
Peter
Did the same but used Allen cap screws from the start.
Pan heads on the seat pans but cap screws along the sides, in front of the spare, baggage compartment bulkhead, equipment mounting behind the panel, etc.
Bill R.
O-360 w/ dual P-mags
SC86 - Easley, SC
www.repucci.com/bill/baf.html
Old 12-19-2019, 11:58 AM
DaleB's Avatar
DaleB DaleB is offline
Are you guys using button head or flush Torx screws? And, if flush, where are you getting them?
Dale
Omaha, NE
Previous RV-7 project (sold)
Old 12-19-2019, 05:05 PM
DaveLS DaveLS is offline
The RV12 maintenance manual specifies the acceptable torex screw. It also specifies other substitution parts like rivets.
MM page 17-3
“Torx Drive Screw
AN526C832-R8 Phillips Truss SS X 1/2 in ↔ Fastenal 0175181 Torx, Pan Head, SS X 1/2 in (0175180, 3/8 in) NOTE: May be used in place of screws that hold all interior panels.“
Old 12-19-2019, 05:09 PM
DaleB's Avatar
I should have been much more specific -- I'm just talking about the 6-32 instrument panel screws.
Dale
Omaha, NE
Old 12-19-2019, 05:18 PM
akabud akabud is offline
They call then 6 lobe, same as torx.
https://www.microfasteners.com/fcmxs...stainless.html
RV-6 Built and sold
Rv-3A Bought. Flying.
Old 12-19-2019, 05:28 PM
DaleB's Avatar
Thanks! I just found those, after searching for "100 degree" without "torx" in the search term.
Dale
Omaha, NE
