Old 11-30-2019, 06:47 PM
bruceh's Avatar
bruceh bruceh is offline
Default Cracked exhaust hanger
I was doing an oil change today, and as usual, I give the entire engine a really good look over. I found one of the exhaust hangers had cracked.
The hanger is made from thinwall stainless steel 3/8" tubing. I know I can source this stuff locally, but making the end flattened looks like it might require some special skills/tools. I don't want to just beat it flat with a hammer. My vise is probably not sufficient to pinch this, and I don't have a hydraulic press.
Any tips, or should I just call Vetterman Exhaust and get a replacement?
Would you replace all hangers, or just the one that is cracked?
Bruce Hill
RV-9A N5771H flown over 900 hours!
APRS Tracking for KJ6YRP and Flying Over the Hills Blog
2021 VAF donator
EAA Tech Counselor, Pre Buys, Build assistance - canopy/tanks/fiberglass/electrical/repairs
Old 11-30-2019, 06:50 PM
pitts flyer's Avatar
pitts flyer pitts flyer is offline
I have 3 unused new ones. If you pay the postage via paypal and a bit extra for the paypal fee, I will send them to you.
Dave
Dave M
RV-4 finished.
Old 11-30-2019, 06:57 PM
Simple to do with a vise.
Replace the broken one and fabricate a set of replacements to keep in your flyaway kit.
Kyle Boatright
Marietta, GA
2001 RV-6 N46KB
2019(?) RV-10
Old 11-30-2019, 07:36 PM
Steve Melton's Avatar
Steve Melton Steve Melton is online now
I'm there at 800 hrs. Why did it fail? Was it connected to the engine or the somewhere else?
Steve Melton
Cincinnati, OH
RV-9A, Tip-up, Superior O-320, roller lifters, 160HP, WW 200RV, dual impulse slick mags, oil pressure = 65 psi, EGT = 1300F, flight hours = 900+ for all
I was born an airplane nut. I have no explanation for it.
www.rvplasticparts.com
Old 11-30-2019, 07:53 PM
RussellT RussellT is offline
As to why the hangers break, having just installed a new 4 pipe Vetterman exhaust I note the accompanying hand drawn installation instruction shows the hangers attached to the engine mount tubes with the flexible rubber section allowing for engine movement. I did not attach mine to the engine mount, instead I went to a sump bolt on each side still with the rubber tube coupler. It seems to me that an exhaust hanger fixed to the engine mount will always break even with lubricated slip joints and rubber coupling. My system seems well supported and I can't see any problems with it other than to ensure the tail pipes have sufficient clearance to allow for the engine movement. What do others do and think about the Vetterman mounting instructions?
Russell
RV 3B. Very slow build. Now onto final assembly...
Old 11-30-2019, 08:15 PM
mine are attached to the sump and upon inspection 10 hrs ago they looked OK.
Steve Melton
Cincinnati, OH
Old 11-30-2019, 08:16 PM
pilotkms's Avatar
pilotkms pilotkms is offline
Default Positive support
Bruce - hangers per plans seemed too ?slippery?. I used 1/16? steel straps 1/2? wide made from ACS stock for end supports. Then bought 1/4? exhaust hanging material from the auto parts store and made straps about 1? wide, to desired length. Use 1/4? holes thru the tire straps and the steel mounts. No issues in 440+ hours. EZ to check and see if they are worn or failing. Flexible yet solid attachment points.
Keith
RV 7A RV #9700 May 2017
N325KS the Flying K
Built in SoCal KCCB, now in GA @ KPXE
800+ Hours & 7X cross the USA
OSH flyin 2018 & 2019 & Petit Jean 2019 & 2021
Old 11-30-2019, 08:28 PM
Sam Buchanan's Avatar
been here awhile
Here are the tubing swaging dies I made from aluminum angle to make a swage that isn't prone to stress cracks:
Put them in the vice and squeeze the tubing:
3/8" steel (not the soft, easily bent stuff) brake line purchased from the aviation aisle at the local auto parts emporium makes great exhaust hangars. I carry a pre-swaged and drilled piece in my flight kit for away-from-home replacement.
Sam Buchanan
RV-6
Old 11-30-2019, 08:54 PM
I flared my tubes slightly. no slip in 800 hrs.
Steve Melton
Cincinnati, OH
Old 11-30-2019, 09:19 PM
that's better than a sharp corner
Steve Melton
Cincinnati, OH
