Old 11-28-2019, 11:13 AM
oren_rokach oren_rokach is offline
Default trim cables routing
Hello Guys,
https://drive.google.com/open?id=1l0...2nX-Vj4pFmIBR4
I routed the trim cables as shown in picture attached . through the small hole, while seen other routing through the big round lightening hole.
Is this acceptable?
It seems like vans also changed the rib over time, it had only one hole once.
Suggestions?
ORen
Old 11-28-2019, 01:52 PM
Phil's Avatar
Phil Phil is offline
I don?t recall exactly, but I think mine is like yours.
As long as the cable is secured at both ends and there is no binding as the elevator moves, I don?t think it really matters.
Old 11-29-2019, 12:19 PM
Mike Hepperlen Mike Hepperlen is offline
Default Trim cable routing
I would use either a snap bushing and drill a hole for it, or an adel clamp to hold the cable off of the lighting hole. This will prevent any rubbing of the trim cable.
Mike Hepperlen
A&P, and EAA Tech Counsellor
Old 11-30-2019, 08:17 AM
Marc DeGirolamo's Avatar
Marc DeGirolamo Marc DeGirolamo is offline
Default trim cable routing
Oren,
Yes that is how I did mine too....make sure that the cable is secured (clamp) to the rib otherwise you may/will get some flex in the cable.
I think the lever trim is not as good a trim system as the -6's and others (vernier/screw) adjust but I couldn't come up with a good way to reverse the cable so built as per plans and its been ok (700hrs) ie. I can live with it.
Marc
Marc DeGirolamo
Canadian..Rv-4 Flying
VAF # 144
Old 12-01-2019, 12:44 AM
jpowell13 jpowell13 is offline
Mine is similar on my 6A, but I stripped some plastic nsulation off some heavy gauge electrical cable and wrapped the trim cable where it passes over the sharp edge of the rib lightening hole just to protect the coating on the trim cable. I secured the insulation with cable ties. John
Old 12-01-2019, 01:01 AM
Originally Posted by Marc DeGirolamo View Post
Oren,
Marc
Thanks Marc!
can you maybe explain what do you mean by clamping the cable to the rib?
A picture from the build?
BR
Oren
Oren Rokach
4X-ODU
RV-10 QB
Blog:
https://4x-odu.blogspot.com/
Old 12-01-2019, 01:05 AM
Good idea! Thanks!!
Oren Rokach
4X-ODU
RV-10 QB
Blog:
Old 12-01-2019, 07:05 AM
ctennis ctennis is offline
Recommend you use some milspec grommet material (M22529/1 from Aircraft Spruce). It will come in handy in quite a few other places in the build.
N29213 - RV8 completed 2017
N955CT - RV10 completed 2021
Columbus, IN - KBAK
Old 12-01-2019, 10:02 AM
rongawer rongawer is offline
Van's sells a wonderful part to solve what you're doing. It's the called the "TIE WRAP CLIP (HOLE), ES-00301". They're available on their online store and perfect for retaining things like trim cables passing through a lightening hole. It uses a 1/2" 6-32 screw (with flat washer and AN365 nut) to mount on the bent lip of the hole. It provides a solid mount for cables, wires, hoses, etc... and eliminates any rubbing concerns.
Ron Gawer
- RV10, N762G, Build in progress.
- Several others that are now just great memories for me.
Old 12-06-2019, 08:32 AM
Hi Ron
Thanks!
Do you have a a photo maybe of this tie wrap?
do you might know if aircraftspruce has it? how does it called?
Vans show no pic of it in their store...
is it this one?
https://www.amazon.com/Panduit-LHMS-.../dp/B005T7SVUK
is it strong enough for holding the trimmer cables? can twist the rib?
Oren
Oren Rokach
4X-ODU
RV-10 QB
Blog:
