Old 11-24-2019, 05:38 PM
Paddy's Avatar
Paddy Paddy is offline
Default New Throttle Handle
While avoiding yard work work this weekend, I decided to make a new throttle handle. I never liked the way the original felt and the fact that it wasn't centered over the quadrant. This handle is made from some 25mm OD 23mm ID carbon fiber tube from eBay. The end caps were turned from some 1" 6061 stock and there's another piece of it turned down and tapped 10x32, bonded inside the tube to attach to the throttle lever with the same hole as the original. Works great and has added 5kts and reduced fuel flow by 1.5gph.
RV-10 N415JS
Slow build kit #40874
Homebuilt Kit Champion Oshkosh 2019
Atlantic crossings: 2
Old 11-24-2019, 10:13 PM
No_0ne No_0ne is offline
Looks great. It must be nice to have talent ...
Old 11-25-2019, 01:06 AM
SuperCubDriver SuperCubDriver is offline
Hey Jim, did you update your weight and balance - or just the performance section in your POH?
RV-7 flying, IO-375 w. P-Mags, 200RV Prop
RV-8 flying, IO-375, P-Mags, 74RV Prop
Old 11-25-2019, 10:56 AM
MGRVAwesome MGRVAwesome is offline
Now.... While you're at it. I would mount a little TO/GA button on that throttle handle. For sure that'll add another 2kts. ;-)
Old 11-25-2019, 11:05 AM
Paddy's Avatar
Default W&B
Herman - I had to update both, the new handle is a whole Kilo lighter than the old one!
RV-10 N415JS
Old 11-25-2019, 11:08 AM
Paddy's Avatar
Default To/GA
You know, I did think about that, even left enough room for the wire inside the handle. Just got to think of something to replace the existing TO/GA button. Chaff maybe?
RV-10 N415JS
Old 11-25-2019, 11:49 AM
I would put this in there. https://www.steinair.com/product/pus...pdt-momentary/ Drill a hole in the left handle end so your thumb can get to it, but recede / countersink it so you don't accidentally activate it.
Old 11-25-2019, 12:22 PM
Paddy's Avatar
Default TO/GA Switch.
The TO/GA button already installed is a DPST. Dual poles are required to isolate the ground between the GTN650 and the G3X. I hadn't seen that SteinAir had a DPST micro switch until you pointed it out. The TO/GA function really is nice, I've used it many times practicing approaches, surreal the way that Garmin A/P flies the missed...
RV-10 N415JS
Old 11-25-2019, 01:57 PM
majuro15's Avatar
majuro15 majuro15 is offline
Paddy, that's an awesome home brewed modification! I'm sure it required going back into Phase 1 with that much change to the air frame. Ha!
www.N1017H.com
Tim Huneycutt, Capt, NCANG
PC-12 Pilot
N1017H RV-10 Flying 2019
EAA #: 1106970
2021 VAF Dues Paid!
