Old 11-20-2019, 10:26 AM
Radioflyer Radioflyer is offline
Default Helicopter engines in planes
I noticed an RV-6A had an HIO-360-B1A engine. (The engine has close to 11,000 hrs total time on it!) How suitable is a "helicopter" variant engine for use as an airplane engine?
Old 11-20-2019, 11:59 AM
crabandy crabandy is offline
I have an HIO-360-A1F6D variant in my 7, but it now has a carb and electronic ignition.
RV 7 500 hours and counting
20 donation done
Old 11-20-2019, 12:44 PM
jask jask is offline
Default Helo engine
They have no ability to have a cs prop installed. There is one in AZ right now that has not flown in 11 years. The odds of that engine being ok is low.
RV-7 builder Ramona, CA.
Free prop balancing for Vanís owners.
Old 11-20-2019, 02:07 PM
Yeah plus apparently the 11,000 hrs TT, even lower.
Nevertheless, other than no CS, I can't find any disadvantage to using a helicopter HIO-360 engine as an airplane engine. I would have thought they had a special cam or more fins for cooling or....
Old 11-20-2019, 02:28 PM
Some H- engines operate at a different max RPM. Some are derated for the rotary wing application while some are flogged like rental go-karts to make max power. It all depends on the engine and the helicopter it was powering.
Old 11-20-2019, 02:57 PM
Toobuilder's Avatar
The HIO on my RV-8 has a CS prop, my spare HIO has provisions for a CS prop, as does my neighbors HIO 360.
In many cases, the "H" designation is simply a unique configuration of "airplane" parts. Cams, cranks, rods, pistons - often identical to the airplane parts, right down to the part numbers.
Michael Robinson
______________
Harmon Rocket II -SDS EFI
RV-8 - SDS CPI
1940 Taylorcraft BL-65
1984 L39C
Old 11-20-2019, 04:45 PM
Default Lycoming engine
From what I see, all of the helo engines came with solid cranks. These are usually old engines, the one in AZ is a 1966, so the cranks may have been replaced if it has a cs prop.
Old 11-20-2019, 05:23 PM
RVDan RVDan is offline
I used to overhaul HIO360D1A engines. Iirc, they had a hollow crank and the case had the port for a governor line, but the crank didn?t have the pickup hole for the oil pressure. I could be wrong, it was 30 years ago.
Dan Morris
Frederick, MD
PA28-140
Hph 304CZ
RV6 built and sold
N199EC RV6A flying
Retired Aerospace Engineer and A&P/IA
Old 11-20-2019, 05:30 PM
FasGlas's Avatar
FasGlas FasGlas is offline
I had a Glasair 1 RG with an HO-360 injected. Had a Hartzell C/S prop. Ran good.
Beech D17S Staggerwing
Lancair 360
Maule M5-235C
Cessna 120
A&P IA
Old 11-20-2019, 05:43 PM
smokyray's Avatar
smokyray smokyray is offline
Default Yea Verily
My RV6X sports an 0-360J2A (Robbie R22)
Helicopter engines vary based on HP, installation and service life. The cool part is some actually are rated higher HP than their aircraft counterparts due to high comp pistons and the fact they aren’t swinging a prop. They also can be found at a bit lower cost.
I like the (0-360) “J” as it’s mounted in the Robbie horizontal and only requires a new fuel pump cam to utilize a mechanical fuel pump. It uses the conical mounts which my previous 0320A also shared. The fan belt hub can be easily removed in lieu of a normal prop shaft ext.
I use a Catto 70/70 2 blade and a Marvel MA4-5, P-Mag, Electroair dual EI.
Great performance, smooth running and 1/2 the price.
Win Win
V/R
Smokey
