Old 10-30-2019, 03:03 PM
rdamazio's Avatar
rdamazio rdamazio is offline
Default F-1070 / F-1069 / F-1013 skipped rivets
Hi all.
In section 29, when riveting the side skins (29-17), it tells me to skip a few rivets, notably some specific rivets that attach to the longeron underneath:
https://photos.app.goo.gl/buG5Ks15yQXi7WiXA
I assume these are riveted later, but I can't find where - what am I missing? When are those rivets set?
(I'm mostly wondering if it's worth/possible to skip ahead, do whatever is needed before setting those, then setting them before the mid-cabin deck is riveted, since that'll be much easier)
Rodrigo
Rodrigo Damazio Bovendorp
San Jose, CA
RV-10 builder #41623
Build log at http://www.airplane.build/
VAF dues paid
Old 10-30-2019, 03:08 PM
Zuldarin's Avatar
Zuldarin Zuldarin is offline
Those rivet holes will be used when you start fitting your doors. Not much you can do until the cabin top is installed and the doors are at least loosely fitted.
Darin
Snoqualmie WA
RV-9A Sold
RV-10 Flying
www.DarinAnderson.com
2021 donation sent!
Old 10-30-2019, 03:15 PM
rdamazio's Avatar
Aha, thanks! I wasn't finding it because I didn't look in the finish kit instructions - it's right there in 45-3
San Jose, CA
VAF dues paid
Old 10-30-2019, 06:32 PM
TFeeney TFeeney is offline
Default Rivets
Keep them in mind though because I haven't found where they tell you to install those rivets.
My cabin top is on and doors are set...holes are still open. They are going to get filled this weekend though before wiring fills in the area and makes bucking difficult.
RV10
QB Wings done
Fuselage done
Systems and electrical...
Old 10-31-2019, 10:15 AM
bwestfall bwestfall is offline
I don?t recall the plans explicitly stating when to fill those holes. As soon as the suffering known as doors are done you can fill them then.
Ben Westfall
RV-10 104EE flying
Coeur d'Alene, ID
Old 10-31-2019, 11:11 AM
RandyAB RandyAB is offline
Lol.....I?m glad I?m not the only one not to find where they revisit these rivets in the plan. Intuitively, once the doors are bonded they serve no purpose and can then be riveted at that time. They also will need to be countersunk since dimpling will be impossible.
______________________
Randy P.
1st time builder
RV10 - QB wings and fuse. Working on cabin top
St. Albert, Alberta, Canada
Reserved:C-GRPY
Old 11-01-2019, 06:21 AM
BartonFlyer BartonFlyer is offline
Hello Rodrigo. I flew with you years ago. I was the Diamond Aircraft salesman. You were considering the purchase of a new DA-40. Do you recall? It was at either SQL or PAO.
I cannot help much with your effort to build the RV-10. I have an RV-8 that I built. I just wanted to say hello and very glad to learn that you are in the RV community.
Keith "Pedlar" Vasey
Overland Park, KS
RV-8, N888KV
1st Flight, September 15, 2008
KC Flight "Wingman"
Old 11-01-2019, 12:07 PM
rdamazio's Avatar
Hey! Yes I certainly do, I'll PM you.
San Jose, CA
VAF dues paid
