Old 10-23-2019, 09:44 AM
odens_14 odens_14 is offline
Default Fuel Tank Quickdrain: Repair or Replace
after almost 10 years, one of my quickdrains on the tank has developed a slow leak that I need to address. I see Van's sells both a full replacement and just the o-ring. My question is the o-ring likely the only issue and replacing that will likely give me another ~10 years or am I just better off replacing the whole thing?
whatever I do I'll do to both sides, so it's likely saving only around $30 to just do the rings but I'd rather spend that on avgas if full replacement doesn't gain me anything.
Chris Odens
West Central, Minnesota
RV-7
Old 10-23-2019, 09:57 AM
Ironflight's Avatar
VAF Moderator / Line Boy
There’s little that can go wrong with them except the O-rings. I have spares on hand so if I have a leaky, I replace it, then change the O-ring on the “bad” one and put it back in the spares drawer for the next time.
No, it doesn’t happen on the same airplane vey often - I just have a lot of planes to maintain.....
Paul
Paul F. Dye
RV-8 - N188PD - "Valkyrie"
RV-3B - N13PL - "Tsamsiyu"
Dayton Valley Airpark (A34)
http://Ironflight.com
Old 10-23-2019, 10:00 AM
ALagonia ALagonia is offline
Repair it with a new O ring and put in your travel tool bag. Buy a new one, they’re cheap to put on the plane. That’s what I did.
I also carry a spare filler cap with me as well you never know.
Old 10-23-2019, 10:02 AM
koupster's Avatar
koupster koupster is offline
Default Both - Repair and Replace
Order a new quick drain and a few o-rings from Van's.
Install the new drain, then repair the old drain and replace it in the other wing. Then repair that quick drain and keep it as a spare. I carry the spare in the airplane.
Cheers, David
RV-6A - A&P
Old 10-23-2019, 10:05 AM
scard's Avatar
scard scard is offline
Like others said.
Plus: There is no need at all to drain the tank to swap the quick drain. Unscrew to the last couple of threads, then quickly remove, place a finger over the hole and either thread your spare in quickly, OR have your spouse just hold her finger there while you swap out the o-ring . "It will just take a couple seconds" might work for you...
Scott Card
CMW E-Lift
VAF Advertiser
Old 10-23-2019, 10:11 AM
Thanks guys! that's a good idea to buy one replacement so I can throw one in the tool bag. it will also make the quick switch easier having one all ready to go. I'll order 1 replacement and a few extra o-rings.
Chris Odens
RV-7
Old 10-23-2019, 10:27 AM
Bavafa Bavafa is offline
Since you are ordering now, another good spare part is the pin/repair kit for the gas cap. Those can also break and leave you stranded. That is another recommended item that is nice to have in the spare/repair kit.
Mehrdad
N825SM RV7A - IO360M1B - SOLD
N825MS RV14A - IO390 - SOLD
N258SM RV14A - IO390EXP119 - in progress
Dues paid
Old 10-23-2019, 01:45 PM
N941WR's Avatar
N941WR N941WR is offline
Buy an entirely new gas cap, not just the repair kit. That way, if a cap comes off in flight, you have a spare.
Bill R.
O-360 w/ dual P-mags
SC86 - Easley, SC
www.repucci.com/bill/baf.html
Old 10-23-2019, 01:47 PM
N941WR's Avatar
Originally Posted by scard View Post
Like others said.
Exactly what I did and it works great. Just get everything laid out and within easy reach. (I put fuel lube on my quick drains before I started.)
Bill R.
SC86 - Easley, SC
Old 10-23-2019, 01:48 PM
jabarr jabarr is online now
Cool tip? use your cleco pliers to hold the drain valve open while you swap out the o-ring.
