Old 09-08-2019, 07:19 PM
DennisRhodes DennisRhodes is offline
Default Maybe a new idea on Jacking points ?
Take a look at the URL and see what you think of the idea for a round tube split block jack point for the main gear. This tool would be handy for removing a wheel / tire or wheel bearing work. It is only a jack point and does require a floor or other style jack. This one is the Homebuilders "model" and it could be CNC router cut and still I believe, affordable.
https://photos.app.goo.gl/LqN2JNJ2Fy93PNKa9
Some of the issues are that MOST RVs have a different axle bend angle and as result the block would be unique to the Model. I think 6 s and 7 ( not A) have the same angle. the 9 as shown has a 48 deg angle and the 9A is ?? different. Don't know about 4 8 or 10s
DRRhodes
2021 VAF Supporter
RV9 N908DR
Old 09-09-2019, 08:09 AM
jeffkersey's Avatar
jeffkersey jeffkersey is offline
Default that works..
That is cool. Maybe a little bulky to keep in the airplane. How much does it weigh? What is the material? I keep a couple U bolts in the plane that I double up on the gear leg to use as a jack point.
Jeff Kersey
RV7A Purchased Flying
Dues paid
Old 09-09-2019, 02:09 PM
AndyRV7's Avatar
AndyRV7 AndyRV7 is offline
You have braided brake lines.
Old 09-09-2019, 02:25 PM
Size is 3 x 2.5x 6 inches. It could be a bit smaller and still work fine. I believe a 3 x2x 5 block would work as well. The material is Delrin a resin acetal plastic from McM C. Machines and drills easily with wood working tools. Yes the brake lines are braded automotive with AN fittings full length from the FW.
DRRhodes
2021 VAF Supporter
RV9 N908DR
Old 09-10-2019, 07:08 AM
daddyman's Avatar
daddyman daddyman is offline
Default really cool design
I've got a old short leg -4.
I'm always looking for a better mousetrap-er-a jack.
Daddyman
Happy Donator to Vansairforce.net
700+ hrs in -4
