Old 07-20-2019, 10:13 AM
tdavis1198 tdavis1198 is offline
Default Build in my Basement
Hi All,
I am planning on a quick build RV-8A. I want to build in my basement. The basement is large but trying to figure out if I can get the large quick build sections into and out of the basement. Does anyone know the dimensions of the fuselage and wings so that I can experiment on manoeuvring in and out.
I do have a double garage but the climate is better in the basement.
Any advice to help me get started is appreciated
Thanks Tony
Old 07-20-2019, 10:36 AM
terrye terrye is offline
You should have a copy of the Vans preview plans (on a thumb drive). Pretty inexpensive and you can print the individual subassembly plans and scale them to answer your question. Overall dimensions are on the 3 view.
Terry Edwards
RV-9A (Fuselage)
2021/2022 VAF Contribution Sent
Old 07-20-2019, 10:49 AM
Mike S's Avatar
Mike S Mike S is offline
Senior Curmudgeon
Default Welcome to VAF
Tony, welcome aboard the good ship VAF
Mike Starkey
VAF 909
Rv-10, N210LM.
Flying as of 12/4/2010
Phase 1 done, 2/4/2011
Old 07-20-2019, 12:13 PM
9GT's Avatar
9GT 9GT is offline
I built 2 Cozy MKIV’s through the tub stage along with the completed wings with vertical stabilizers attached in my basement. We cut a hole in the family room floor about 8’ x 10’ and pulled them up and out when the time came. Start to finish that hole set me back about $200 dollars in lumber and 4 hours of work to open it and close it back up and re-stretching the carpet. Go for it!
David C.
Howell, MI
"Donor Exempt" but donated through Dec. 2021
Old 07-20-2019, 12:49 PM
Don Patrick's Avatar
Don Patrick Don Patrick is offline
Default Garage
Hey Tony,
I?m in Oshawa...built my slow build 8 in my single car garage.
I just had a plug in oil rad heater and I as comfortable all winter long.
Unless you have a straight in and out of your basement or a walk out, I would stay in the garage.
Good luck!
If you need a hand with the build, I?m not too far.
Don
Originally Posted by tdavis1198 View Post
Hi All,
Thanks Tony
Old 07-20-2019, 12:51 PM
Kyle Boatright Kyle Boatright is online now
Hi All,
Thanks Tony
An RV-8 is going to have wings that are ~11' long with a 4' chord. The fuselage is going to be roughly 3' wide x 3' tall, x 16ish feet long without the engine, cowl, empennage, or landing gear installed.
Kyle Boatright
Marietta, GA
2001 RV-6 N46KB
2019(?) RV-10
Old 07-20-2019, 01:07 PM
fl-mike's Avatar
fl-mike fl-mike is online now
what is the width of the entry door?
Without the turtledeck, turtledeck bulheads, rollbar, instrument panel, upper fwd baggage bulkhead, and midsection brace, you can get the "canoe" on it's side out a 32" wide door. frame (door removed) Limiting factor is the firewall height.
Wings are not a problem if you have the height in the stairwell to make the "tilt"
Mike W
Venice, FL
N164WM
N184P reserved (RV-8QB)
Old 07-21-2019, 07:09 AM
phapp phapp is offline
Default It can be done.
My basement was a garage-under. So it has a garage door.
It took careful measurement and precise positioning, but turned out I could mount BOTH! wings. I was even able to squeeze by the wing tips and not have to walk around the long way.
After the critical incidence drilling, they came back off.
Tail feathers were not an issue at all to mount, but the HS will not fit thru the garage door. Not a problem for me as I only had it on for the trial fitting/install and wanted it off for painting.
Here are some links to pics:
https://drive.google.com/file/d/12aR...ew?usp=sharing
https://drive.google.com/file/d/1NTX...ew?usp=sharing
https://drive.google.com/file/d/1hnK...ew?usp=sharing
https://drive.google.com/file/d/1d8Z...ew?usp=sharing
https://drive.google.com/file/d/14t9...ew?usp=sharing
2021 - 2022 Dues Paid
N423PH Schweizer 1-23 (Sold)
N83881 Champ 7AC
N446PH RV8 (reserved)
PA-25 Pawnee Glider Tow Pilot (volunteer)
CallAir A-9 Glider Tow Pilot (volunteer)
Old 07-21-2019, 10:40 AM
azonic75 azonic75 is offline
Here is a friend of mine doing the extraction!
https://m.youtube.com/watch?v=CQI-nE946mc
RV-8a Flying
RV-10 Building
J-5A Flying
Extra 300 flying
Old 07-21-2019, 11:15 AM
Carlos151's Avatar
Carlos151 Carlos151 is offline
Built mine in our temperature controlled basement. All clearance measurements were made prior to placing the fuselage on the gear. Rolled her out with the help of a car dolly under each wheel. Clearance from the gear to the house walls and pylons was less than 1/2" on each side as planned. Like a Chinese jigsaw puzzle but we had her out in about an hour. No walls to tear down, no holes to cut. Get a set of plans, measure and compare to the room you need in your workshop. Empennage assembly was done in the garage and final assembly was done at the airport. From the pictures you see to flying was about 2 months since most everything had already been done in the shop.
Karl Richcreek
RV-8
N151TK "La Otra Chica"
Flying as of August 14, 2015
TN26
