Old 07-07-2019, 06:52 PM
bkervaski's Avatar
bkervaski bkervaski is offline
Default N196 1st Condition Inspection
Well, that was uneventful.
Did the first condition inspection, only 1 loose bolt (aileron autopilot servo bracket). No other squawks. Nice.
Vic: All my jam nuts were still tight
RV-14A #140376
N196 (Flying)
2019 Bronze Lindy
Old 07-07-2019, 08:16 PM
mturnerb mturnerb is offline
Wow that year went quick. Any unusual / interesting wear items? I'm close to finishing phase 1 and did an oil change today - FWF looked good when I pulled the canopy. Found one loose cable tie.
Turner Billingsley
RV-14A built/sold N14VB
RV-12iS in progress as of October 2020
Old 07-07-2019, 08:46 PM
bkervaski's Avatar
The only thing that I found was the tail top fairing rubbed a wear mark into the paint in the front towards the top. Considered trying to fix it but I would probably make it worse.
There's some debris and grime in the tail cone where I had an oil leak from a connector on the oil cooler about 75 hours in. It coated the bottom of the airplane, some of it made its way in to the tail cone somehow. I'll need to crawl back in there at some point and clean it up.
Sending some oil off to Blackstone for analysis.
That's really it! Better than expected.
RV-14A #140376
N196 (Flying)
2019 Bronze Lindy
