Go Back   VAF Forums > Model Specific > RV-9/9A
Old 07-01-2019, 05:02 PM
tjo tjo is offline
Default Really tight fit of the control stick to stick base
This seems too tight to me, anyone else experience this? I had to bend the Clevis out slightly to get the stick base in and it just doesn’t look good.
https://www.flickr.com/gp/182432065@N08/d7c61J
If you zoom in on this pic you can see how the flange of the Clovis is bent out to fit the control stick base.
Old 07-01-2019, 05:19 PM
pazmanyflyer's Avatar
pazmanyflyer pazmanyflyer is offline
Originally Posted by tjo View Post
This seems too tight to me, anyone else experience this? I had to bend the Clovis out slightly to get the stick base in and it just doesn’t look good.
My -7 instructions say to grind ends of stick and bushing for slip fit. See detail B, section A-10 (lower left), Note 2 on sheet dwg 38 (again for this is for a 7) but should be the same for the 9 since they share the fuse.
From your picture you still have to much bushing. There shouldn't be any bending of the clevis.
Carlos in Arizona
EAA Chapter 538 www.chapters.eaa.org/eaa538
Wittman Tailwind W8 N53CH (built & sold)
Pazmany PL-1 N2029 (bought & sold)
RV7 - N537TC (reserved & building)
Emp, Wings & Fuse done - working on FWF
"The air is an extremely dangerous, jealous and exacting mistress. Once under the spell most lovers are faithful to the end, which is not always old age." - Winston Churchill
Old 07-01-2019, 10:41 PM
tjo tjo is offline
Yep, the note was there, thanks.
Tim
Old 07-03-2019, 08:21 AM
AAflyer's Avatar
AAflyer AAflyer is offline
Default Grind it, baby!
You may find you'll need to grind/trim BOTH the bushing and the tube at the bottom of the stick. My -8 instructions, IIRC, talks about the "Clovis", as you call it, being angled, just like yours is, in your picture, but this was on purpose. The bushing was to be ground (grinded?) at a matching angle at the ends so that it would help prevent it from rotating when the bolt is tightened.
Bruce Windom
QB RV-8 N148BW
First Flight: Oct '16
AeroSport Power IO-360 180hp w/dual P-Mags
Catto 3-blade, with black carbon spinner.
10" Dynon SkyviewTouch. That's ALL.
Old 07-03-2019, 11:30 AM
rvbuilder2002's Avatar
Actually it is to prevent the bushing from getting bowed when the bolt is torqued which will cause binding in the pivot joint. For this reason, it is a good idea to adjust the ends of the bushing for a good fit, regardless of what model you are building.
Scott McDaniels
Hubbard, Oregon
FAA/DAR
