Old 06-25-2019, 03:06 PM
Av8torTom's Avatar
Default My Garmin Remote Transponder
Think I?ve settled on a spot for my Garmin remote transponder
Thoughts?
N677AT reserved
Superior XP O-320, 160HP
Old 06-25-2019, 05:55 PM
ColoCardinal's Avatar
ColoCardinal ColoCardinal is offline
Tom,
Having a little trouble seeing your photo due to its size.
That said, I installed mine vertically above my left foot. Makes it VERY easy to get out. here's more than enough space, verically, and it doesn't take up so much horizontal room. Loosen the screw, flip the lever, and it drops into your hand.
Carl - - Morrison, CO
N16CB RV7A
Airworthiness cert issued 12/24
best X-mas present I could have hoped for!
paid 'til 10-19
Old 06-26-2019, 10:53 AM
BoilermakerRV's Avatar
BoilermakerRV BoilermakerRV is offline
Default Similar Location
This looks like more or less the same spot I chose for my GTR 20 remote COM unit. It will be a little difficult to get to after the top skin goes on, but I'm hoping that won't be often.
Michael
Danville, IN
RV-7A Canopy/Finishing
N317PU Reserved
2020 Dues paid (February 2020)
Old 06-26-2019, 01:54 PM
BSwayze's Avatar
BSwayze BSwayze is offline
Just an alternative thought... I mounted my transponder behind the baggage bulkhead. Easy access, and simple wiring. It sits right above the antenna that's on the belly. Your space behind the panel will get crowded, and this freed up some room there, too.
Bruce Swayze
RV-7A Standard Build
http://www.BrucesRV7A.com
Old 06-26-2019, 02:46 PM
snoop9erdog snoop9erdog is offline
I mounted my GTX45R(tray removable with nutplates) behind the right sub panel (vertical rectangular opening in the sub panel) along side the right rib. That way all I need to do is remove the 460 MFD and then I have direct access to pull the XPDR. If anybody would like pic I can send them. PM me.
I got the idea from Chris Hrabe...another 9 builder....
Cheers
Ed Avila
St. Johns, AZ (SJN)
N646A RV9
Worlds longest RV build...but getting there
Old 06-26-2019, 03:13 PM
Av8torTom's Avatar
Default Space
Does space really become a premium between the subpanel and the firewall?
Between the panel and subpanel for sure, but behind the subpanel?
N677AT reserved
Old 06-26-2019, 03:24 PM
The space between the panel and the sub......the sub to the firewall seems to be about the same distance/length
Ed Avila
St. Johns, AZ (SJN)
N646A RV9
