UnPossible
I am at the point I need to rivet down the baggage and rear seat floors to move ahead.
I think I have everything run that I need to run, but wanted to check with those that have gone before me.
I have 5 conduits running from under the flap cover to behind the baggage bulkhead.
I also have 2 #2 (starter and ground) and 2 #6(dual power bus) wires run, as well as the static tubing.
The hoses coming up either side of the center tunnel are for the AC system.
Is there anything else I should consider running now, or am I ready to steam ahead?
Jason
Jason
